      05-27-2020, 11:51 AM   #1
yoshix1
Drives: BMW X1
2013 X1 xDrive 35i M Package Tires and Wheels sizing
Hello All,
seeking wisdom here from All of you experts. I'm about to have to replace my tires, but I'm deciding if I should stick to 19" or if I should go down to 18". The dilemma is the following, I'm currently using 225/40 R19 (rear) and 255/35 R19 (front) run-flats, I wouldnt mind staying with the 19" but I want thicker look. Now, I would like to go down to 18" , looking for the thick look, meaning wider tire on the back with not so low profile, but still low profile but not as much and non-run flats. What would be the best size to use?
I hope I'm making sense.
I'm not too knowledgable when it comes to specs, I'm mostly about looks.
Thank you in advance for all the knowledge shared here.
Cheers,
Yoshi
      05-27-2020, 12:04 PM   #2
bassrebel
The Lazy one...
Drives: 16 C300 4Matic
These two posts will offer a lot of knowledge on this topic...
https://e84.xbimmers.com/forums/showthread.php?t=820397
https://e84.xbimmers.com/forums/show....php?t=1510503
I would go with the 18's and you can run 245/45/18 all day without any problems or rubbing issues
Follow me on Instragram @bassrebel
2014 BMW x1 x3.5i 2016 Benz C300 4Matic
      05-27-2020, 01:45 PM   #3
yoshix1
Drives: BMW X1
bassrebel thank you much for the quick response. Greatly appreciated. I will go for 18" in order to have more rubber, mind you, I love the way it rides right now but the run-flats don't last that long, pricey, and I also want the thicker look with tires... I also don't want to risk the specs of it.
thanks again bassrebel
      07-19-2020, 06:42 PM   #4
E46M3E84X1
Drives: Xdrive 35i
Did you stay with the 19s?
Looking at 235/40 and 265/35 wondering if this is the best choice.
Let me know if you found something.
