      03-02-2015, 11:42 AM   #1
rps
rps's Avatar
Drives: 2013 X1
Comfort access rear door handles
Just wondering if other people with comfort access can open the rear doors when the car is locked. The front doors respond immediately, but nothing happens if I try the back doors. I have a "glitch" in the main computer so the car will be going to the dealers and didn't know if I would have to have them look at the rear doors also.
NB8S Past Garage: Z4, 135i. Present Garage: 2013 X Drive X1 2.8i.
      03-02-2015, 12:12 PM   #2
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
There's no sensors on the back doors. You have to use your remote, or the button on the dash.
      03-02-2015, 12:25 PM   #3
Twix
Twix's Avatar
Drives: 2011 e91
Or put your hand in the front door handle for a second then open the rear
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      03-02-2015, 01:42 PM   #4
spydrz
spydrz's Avatar
Drives: '15 M4, '15 i3
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
That only comes on some of the more 'spensive models.
2002 X5 3.0i/man.*
2006 330i/man./Arktis/Grau*
2001 525i/step./Schiefergrün/Sandbeige*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Dinan Stage 2
*retired
      03-02-2015, 02:11 PM   #5
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Mine won't work this way, unless you use the pass. side front door. It unlocks all doors when touched, but the driver's touch pad only unlocks the one door. I thought it was a strange anomaly.
      03-02-2015, 02:14 PM   #6
Teutonic
Teutonic's Avatar
you can set it up to open all.
      03-02-2015, 02:50 PM   #7
Aerospike
Drives: 2013 F20 M135i
Zeevette, to expand on Tracus' post. From the main menu, go into vehicle settings, should be a setting that says 'lock' or something like that. Call me crazy, but I set mine to unlock only the driver's door one that side to avoid unnecessary wear on the other three lock servos.
      03-02-2015, 03:49 PM   #8
Red Bread
Drives: Smog machines
Okay, crazy. I've never had a lock cylinder fail. I've never even heard of anything other than the ignition cylinder failing.
      03-02-2015, 04:04 PM   #9
Aerospike
Not the cylinder, the servo that actuates it. It has failed on my truck, but it's a Dodge.
      03-02-2015, 04:04 PM   #10
Teutonic
Teutonic's Avatar
I kinda understand the guy...
Call me crazy, but I am using the wipers as less as possible to not scratch the windshield... Makes sense?
(It is however bombarded by the gravel that the city throws on the streets.. )
      03-02-2015, 04:06 PM   #11
Red Bread
Haha. The things my old BMW had die were the things I never expected. The auto dimming mirror dripping heavy metal onto the center console. The rear shock mounts lasting a shorter amount of time than it took to access them. The climate control crapping out and requiring a whole new ECU. But the locks and wipers worked fine.
      03-02-2015, 04:58 PM   #12
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Cool, gracias!
      03-04-2015, 08:26 AM   #13
Aerospike
My technical argument is sound: the servos are rated to a certain number of cycles, the more you use them the shorter they last. I did, however, preface that argument with 'call me crazy' not 'stupid' to avoid using windshield wipers :P. Welcome to the world of an OCD who waxes his tool chest and cleans his drill bits after each use.
      03-04-2015, 05:14 PM   #14
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Man, you need to have a couple of beers, and chill...
      03-04-2015, 10:05 PM   #15
Twix
Twix's Avatar
Drives: 2011 e91
I throw my drill bits is the metal bin after I use them maybe 3-4 times. Cheaper to borrow them from work than buy a drill doctor.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      03-05-2015, 06:49 AM   #16
Aerospike
I can't do any home improvement projects without beer. The alcohol really helps me accept the builders' 'that's close enough' dimensional tolerances.
