      02-09-2015, 07:16 PM   #1
rps
rps's Avatar
Drives: 2013 X1
Nav update question
I just received the 2015 Nav update on USB, does anyone know how long it takes to download into the cars HD?
NB8S Past Garage: Z4, 135i. Present Garage: 2013 X Drive X1 2.8i.
      02-10-2015, 02:00 PM   #2
Mr Kleen
teh porcupine
Mr Kleen's Avatar
South Korea
96
Drives: 2020 Tesla 3 LR AWD
2013 BMW X1  [10.00]
1 USB or 3? I had to use 3. It took a good 10 minutes for the first 2, maybe 5 for the last one to finish.
      02-10-2015, 02:15 PM   #3
tpm17
Drives: 2014 BMW X1 35i
Is the 2015 Nav update worth it? I have a 2014 X1
      02-10-2015, 03:39 PM   #4
rps
rps's Avatar
Drives: 2013 X1
Just 1 USB stick OEM BMW.
      02-10-2015, 03:40 PM   #5
rps
rps's Avatar
Drives: 2013 X1
Mine is a 13. I update x2 years, not every 1.
      02-10-2015, 03:41 PM   #6
rps
rps's Avatar
Drives: 2013 X1
Thanks for the info
      02-11-2015, 08:26 PM   #7
rps
rps's Avatar
Drives: 2013 X1
Took me ~1 hr, for anyone else contemplating the up-grade. I have the USB stick for sale in the classifieds.
      02-12-2015, 02:07 PM   #8
donrobin
Drives: 2013 X1 335i
Did it work alright and can a 2013 model use the stick to update maps?
      02-12-2015, 02:41 PM   #9
rps
rps's Avatar
Drives: 2013 X1
Worked fine, mine is a 13
      02-17-2015, 02:50 PM   #10
NumberSix
Veloce
NumberSix's Avatar
Drives: Future X1???
As a piece of trivia, the release code for my update is the same as the one that was provided for the original nav system in the car.
BTW, a USB update is available in the For Sale by Member section
I may not have ended up where I intended to go,
but I know I've ended up where I'm intended to be.
-Douglas Adams
      02-23-2015, 02:56 PM   #11
akd_dallas
Drives: 2013 X1
Does anybody have any instructions on installing the navigator update from a USB stick? I got it from BMW wit an activation code, but NO instructions? How do I use the activation code?
Thanks...!
      02-23-2015, 02:58 PM   #12
akd_dallas
Drives: 2013 X1
Can you share how to install the update, and how to use the activation code? I got the USB from BMW, and it came with the activation code, but no instructions.
Thanks
      02-23-2015, 05:32 PM   #13
NumberSix
Veloce
NumberSix's Avatar
You should have found a little booklet inside the jewel case they sent you.
Basically, you get in the car, turn it on and insert the USB into the glove box port.
When the system identifies the stick, you can click on "Start Update"
Provide the 20 digit code and click "OK"
When finished it will display "restart the System" and then with the iDrive click "OK"
Remove the stick and use it for whatever you want. It is a 32G USB so it would hold a lot of music.
BTW, DO NOT remove the USB until the update is completed. You can power down the vehicle and the update will resume on the next key cycle.
Your dealer should also have the booklet or, at least the instructions
-Douglas Adams
