      10-25-2010, 03:07 AM   #1
bjotings
Norway
Drives: X1
Time to change wheels for the winter!
I have a standard garage-jack. but do I need some blocks to put into the
jack-supports on the underside of the chassis in order not to break them? I know the original BMW jack will fit straight into the jack-supports - but a garage jack is simpler to use.
Re
BT
      10-25-2010, 12:37 PM   #2
tompak23d
tompak23d's Avatar
Drives: iX M60
There is two center points, one in the front and one at the rear, where you can use the garage-jack to lift both wheels at the same time. They are easy to locate.
      10-25-2010, 07:48 PM   #3
strobe
Australia
Drives: 440i Grand Coupe
Jack position on X1
I have a similar comment - I used my 2010 C Class Mercedes jack as it has the same jack head size and fits the X1 jack slot fine.
When using a jack I like to place a safety block under the X1 while removing the wheel but I am unsure where to place it.
Can anyone help with front & rear locations ?
      10-27-2010, 08:45 AM   #4
BearX1
Drives: 2006 320dt M-sport
Re
BT
Hei, jeg brukte bare en liten trekloss mellom garasjejekken og løftepunktene under bilen. Det gjør løftet noe mykere samt at treklossen festet seg i sporene på jekken. Men viktig at klossen er solid nok slik at den ikke sprekker når du jekker opp bilen. Nå venter jeg bare på snøen
      11-18-2010, 03:45 AM   #5
LRS
Dead Head
LRS's Avatar
Drives: E92 335d Coupe
Location: (Then > Bay Area, Calif) (Now > Southeast, UK)
Getting the X1 xDrive fitted with Nokian WR G2 225/50 R17 98V XL M+S tyres.
Will let you know how we get on as we plan to run these all year round as they are clasified as 'All Weather Plus' tyres with the M+S specification.
E92 335d SE Auto | Space Grey | Black Leather | 19” 230 Star Spoke | Comfort Access | Lumbar | Heated Seats | Black High Gloss Trim | Pro Nav | Assist | Bluetooth Telematics | Voice Control | High Gloss Shadow Line
