      02-09-2014, 08:58 AM   #1
halfmoonclip
Drives: X1 28i
Tire pressure settings
Did a quick search with no success, so here's the question.
My X1 calls for 35 F, 41R. My bride's Audi has separate settings F/R, depending on how heavily laden the car is.
No complaints on how the X1 has been handling, but I wondered if anyone was aware of or had made adjustments to tire pressure based on how much was in the vehicle?
Thanks,
Moon
      02-10-2014, 04:01 AM   #2
0w40X1
Drives: 2014 BMW X1 s28i M Sport
I tracked my X1 s28i with 225/45r18 and 255/40r18 tires with a temp gauge to figure it out.
I decided I liked 38 psi all around at 70 deg ambient cold.
The rear seems to be very bouncy even at this lower pressure.
I think the book says 38 psi front and 42 rear under heavy load so that's probably just right.
      02-10-2014, 03:48 PM   #3
halfmoonclip
Drives: X1 28i
Doorjamb says 35/41. An automakers greatest fear (along with unintended acceleration) is having a car exit the road bassackwards, which no doubt explains some of the higher pressure in the rear (along with the ability to carry heavier loads.
We're headed out on a trip shortly, and I'm going to stick with the factory numbers for the moment, largely due to the full load.
More input is gladly accepted.
Moon
      02-10-2014, 05:49 PM   #4
squishy
Zimbabwe
153
Drives: 2014 Ford Mustang GT
I have aftermarket tires/wheels, and the dealership recommended I stay at 35 psi front and rear.
No complaints; handles nicely.
      02-13-2014, 04:35 PM   #5
philsteroni
Drives: 325xi
The info is in your owners manual. I've seen it there before.
      02-13-2014, 08:29 PM   #6
halfmoonclip
Drives: X1 28i
I'll have another look in the manual, and I may well reduce the pressure in the rear when the car isn't heavily loaded.
Thanks,
Moon
      02-13-2014, 10:03 PM   #7
halfmoonclip
Drives: X1 28i
Okay, a thoro' perusal of the manual only produced the 35/41 numbers as correct for the tire size on my car (225/45 R18), so it isn't really an answer.
Moon
