      10-22-2014, 12:01 PM   #1
lyndellw
Drives: 2015 BMW X1 X Drive
small bulb inside headlamp
Just upgraded my headlight bulbs with the Phillips bulbs. Anyone know how to disable the small bulb w/o getting a code?
      10-23-2014, 09:04 AM   #2
BaritoneJP
BaritoneJP's Avatar
Drives: 2014 X1 sD28i mineral grey
If you have iDrive, then you can do that in the Lighting section.
      10-23-2014, 11:44 AM   #3
lyndellw
small bulb inside headlight
I do have iDrive, but I had no luck turning off the small bulb. I have the DRL's disabled. Thanks for the tip anyway.
      11-02-2014, 01:40 PM   #4
kurtthewurt
kurtthewurt's Avatar
Drives: '13 X1 sDrive28i, Mineral Grey
It's the parking lamp, and it comes on along with the side markers and tail lamps whenever the headlamps are on. I asked the tech who does my coding and he says there's no option in the system to disable it (booo)
      11-02-2014, 10:21 PM   #5
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
If that's the cornering lights they can be disabled via coding. Also the may be deactivated if the lighting switch is not on auto.
With xenons the fog lights act as cornering lights but i disabled them via coding.
