      03-03-2014, 11:54 PM   #1
paradoxical3
Will 265/35/18 fit in the front? Anyone done any fender rolling?
I am looking to get some Dunlop Direzza Zii for the track, but not sure if a square setup will fit. I'm looking to run 265/35/18 in the front. I'm willing to roll the fender, but not sure if it will fit.
I will probably wind up with Apex EC7 or ARC8 wheels.
      03-04-2014, 07:24 AM   #2
Twix
Twix's Avatar
Drives: 2011 e91
A tire that wide in the front well do nothing but hurt your scrub radius. I can almost guarantee something in the power steering system will fail.
      03-04-2014, 07:26 AM   #3
paradoxical3
Huh? Thousands of people this platform run 265 square setups. It helps improve turn-in on tracks, provides more overall grip, and reduces understeer. The power steering handles it just fine.
My question was whether it will fit on the X1, since it is a different wheel well than the 335/135 where people run them.
      03-04-2014, 08:42 AM   #4
BeemerX1
Belgium
14
I can't really help you with a answer.
Try http://www.willtheyfit.com/ so you have a idea how much further your rim will go to the outside (or little to the inside as well).
265 is a lot in the front but can't say if it possible or not or if it is still healthy for the xdrive and steering.
Good luck
      03-04-2014, 08:45 AM   #5
Black Flagged
Black Flagged's Avatar
Drives: M2C
i don't think you will need to roll the fender with 18's if you have not drop your ride... if its slammed like wantm135 then maybe, but with a spring drop it should be fine...
      03-04-2014, 10:34 PM   #6
wantm135i
wantm135i's Avatar
Drives: x1 35i m sport
hey man iam running 255/35-19 and a 15mm spacer all around, if you run a 265/30-18 no problem if on stock camber. that extra hight in the side wall at 265/35 might be to much the 265/30-18 would be perfect for the track.
