      09-26-2012, 11:38 PM   #1
Humble_Bear
Drives: 01 530i,10 Golf,11 Sorento V6
Can you paddle shift even in D mode
I would like to know if you can paddle shift even if you are in D mode? I know many other cars can temporarily manual paddle shift up or down and then it would go to auto after several seconds.
      09-27-2012, 01:20 AM   #2
nigelm
England
Drives: X1 xDrive23d
Yes you can. I find this very useful e.g a quick downshift or two to get some 'engine braking' when going downhill, or prior to overtaking.
      09-27-2012, 11:05 AM   #3
heisalan
Photographer
heisalan's Avatar
Drives: X1 xDrive28i
Agreed. The best part of it is when you make a big sharp cornering, just downshift to get engine brake, so that you don't need to press the brake. Engine brake is very effective. (Guess that will cause more abrasion to your engine?)
2013 X1 xdrive28i Marrakesh Brown / Beige
      09-27-2012, 12:51 PM   #4
Humble_Bear
Just to verify, you don't need to shift into M to use the paddle shift correct, you can do it in D? After you shifted, does it revert back to auto if don't shift any more?
      09-27-2012, 02:35 PM   #5
dingox01
Drives: x1 28i
It reverts back to auto if you don't shift any more.
      09-27-2012, 03:06 PM   #6
Humble_Bear
Thanks, that's awesome!
