      09-07-2014, 10:32 PM   #1
Redsoxx1918
Drives:
Is the key fob for the 2015 X1 a new design or identical to the 2013 version? Anyone have a chance to compare the two?
      09-08-2014, 04:49 PM   #2
Redsoxx1918
Drives:
Could someone post a pic of their 2015 Fob?
      09-08-2014, 05:26 PM   #3
Black Flagged
Black Flagged's Avatar
Drives: M2C
I'm sure it's the same, they are both an E series and the FOB doesn't not change until the F series. Then the key gets bigger
      09-08-2014, 06:00 PM   #4
Veritas-II
Veritas-II's Avatar
Drives: 2015 X1 2.8i xDrive M-Sport
Confirmed. I have a '15 X1. It has the same fob as my '11 E90.
      09-09-2014, 10:13 PM   #5
AWF87M2
AWF87M2's Avatar
827
its the same. Pretty lame that BMW used left over parts for the E84, at least give us key less start feature like on the f30 so those without comfort access don't have to insert the key every time we start the car...
      03-09-2020, 11:00 AM   #6
nasikhan
Drives: X1, E84, 2012, sDrive20d
Hi, anyone knows how to program a used key, I bought a used x1 e84 2012 model but it came with one fob, I have bought one off ebay and trying to google around how to program it but no luck so far. Thanks
      03-09-2020, 11:18 AM   #7
Kevman
Kevman's Avatar
45
Drives: 2019 BMW X3 x30i
My car wont start unless I plug the key into car. Both fobs, and its not the battery. Otherwise works fine.
      03-09-2020, 01:59 PM   #8
Chicone
Drives: 2015 X1 X35i M-SPORT
As far as I know that's a Dealer only or very capable locksmith item. Also, the built in physical key would not be a match.
-Steve
2015 BMW X1 35i MSport // BMS Intake
      03-09-2020, 07:51 PM   #9
kringer2
Drives: 2014 X1 28i xdrive
I think you have to insert the key if you don't have comfort access.
      03-10-2020, 04:36 PM   #10
Kevman
Kevman's Avatar
45
Worked from my pocket until about a year ago.
      03-26-2020, 12:15 AM   #11
qazq6950
qazq6950's Avatar
Drives: 2015 X1 E84 Sport Line
Hi,
With mine I programmed another key (at least I think it wasn't programmed before, dealer gave me 2 and only 1 worked) by putting the new key in the ignition slot and starting it with the old key in the interior of the car. I switched the car off and the new one worked. Hope this helps.
      03-26-2020, 07:40 PM   #12
BMWX1-35i
2015 X1 35i XDrive with NAV
BMWX1-35i's Avatar
Drives: 2015 X1 35i
If I already have a working key fob, do I still have to go to the dealer or can I purchase a new one and program it myself?
2015 X1 35i XDrive
Ultimate, NAV & Cold Weather Package
MHD, FTP Motorsports Charge Pipe, Drop in K&N
      03-30-2020, 12:22 PM   #13
qazq6950
qazq6950's Avatar
As far as I know I think you can just buy any used key of that style and program it yourself.
