      04-13-2014, 01:18 PM   #1
wantm135i
wantm135i's Avatar
Drives: x1 35i m sport
took bmw x1 to the drag strip track first time 1/4 mile run
took bmw x1 35i m sport to the drag strip track first time all stock. i ran a 13.95 in the 1/4 mile run at 100 mph
      04-13-2014, 01:29 PM   #2
paradoxical3
Not bad, considering you have a 2.0 60ft time a better launch will get you into the 13.5 range. Brake boost to 2500RPM and then floor it when light hits green, manually shift at 6200RPM each time. What car did you beat there
      04-13-2014, 05:06 PM   #3
wantm135i
wantm135i's Avatar
i beat a ford mustang, i thought i was to shift at 5500 rpm thats what i shifted at i read one of your post saying that.
      04-13-2014, 06:59 PM   #4
paradoxical3
Depends on what mods you have, it slightly changes the torque curve. Probably didn't matter too much, you just don't want to go to 7000rpm.
      04-14-2014, 12:05 AM   #5
wantm135i
wantm135i's Avatar
hey para since you have the alpina flash, when your at the drag strip what is the trans postion? in drive or do you move it over to sport and if the alpina flash flashes over the sport mode do you use paddles or the shifter? thanks iam going agine this friday to the track and want to start with my best base line before adding mods.
      04-19-2014, 12:20 AM   #6
wantm135i
wantm135i's Avatar
bmw x1 1/4 mile time e84 35i m sport stock
i just got back from the track tonight, i ran a 13.6 in the 1/4 mile run all stock. now iam ready to buy parts.
      04-19-2014, 12:30 AM   #7
paradoxical3
Nice! I think that's the fastest stock X1 run, I never ran mine stock and all the magazines had 13.9. What's even more amazing is that you can definitely get that 60ft down even more!
101.49 is a strong trap stock.
To answer your previous question I put the car in M mode. So I put the shifter into sport but pull a paddle to switch into manual before I enter staging at the drag strip. That way I'm already in M1 when I am ready to go.
One more tip - you already know you are supposed to shift around 5500-6000 rpm. But if you are approaching the end of the 1/4 mile and have enough revs left, try to finish without shifting even if you are at 6500-7000RPM. The time you save by not shifting is more than you lose by not being in the torque curve.
      04-19-2014, 12:32 AM   #8
wantm135i
wantm135i's Avatar
thanks bro, now iam buying all the parts to mod the motor
      04-19-2014, 06:17 AM   #9
Naambezet
Netherlands
11
Drives: BMW X1 sDrive 20i
You do, you still have more torque on the wheels in the first 4/5(?) gears due to the gearing.
      04-19-2014, 07:22 AM   #10
paradoxical3
You definitely do not want to shift at 7000 RPM with the N55 engine, especially tuned. The power falls off so hard; this has been tested countless times by the guys in the 335 forums.
      04-19-2014, 08:40 AM   #11
Twix
Twix's Avatar
Drives: 2011 e91
Shifting at red line is usually a power killer for most cars. Find that sweet spot and set up a shift light for about 200 rpm before it. You'll hit your target every time.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      04-19-2014, 04:01 PM   #12
wantm135i
wantm135i's Avatar
just what i need to know thanks.
