      03-31-2015, 08:22 AM   #1
improvius
Drives: 2015 X1 X28i
Another offset question
Assuming my local dealer gets his head out of his butt, I'm about to place a build order for a 2015 X1 x28i. Replacing the stock wheels/tires is at the top of my to-do list. I'm leaning towards Miro 112, square setup with 18x8.5 ET 35 all around, with 235 tires. I'm a little concerned about possible rubbing on the front suspension, though. Would this setup be okay, or should I maybe go with 5mm spacers in the front?
(And yes, I did search the forum, but couldn't find a definitive answer.)
Thanks!
      03-31-2015, 11:18 AM   #2
BeemerX1
Belgium
14
http://www.willtheyfit.com
-> check this out
Compared to the 8x20 225/45/18 ET30:
Compared to your existing wheel, this new wheel will have an inner rim which is 11.4mm closer to the suspension strut. The outer rim will poke out 1.3mm more than before.
Almost 12mm is a lot. Is it to much? I don't know, mine is only 6mm to the inside and I have plenty of space.
The site is full of info from people with different wheels 8.5x18 is a widely used setup on the site I have seen so far.
Good luck.
      03-31-2015, 01:01 PM   #3
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
I know they'll fit. I just installed 19x8.5 ET35 wheels, with 245-40/19 tires, and no problem.
      03-31-2015, 02:12 PM   #4
improvius
Great! And no rubbing on the suspension? Hmm, maybe I'll go 245 as well... Z, what wheels did you end up with?
      03-31-2015, 05:41 PM   #5
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
I went staggered, with Niche Targa/Conti Extreme DWs, in 245-40/19 on the fronts, and 19x9.5 ET20 rears, with 275-35/19s. I made a mistake with the rears. I should have chosen the option of ET35 on the rears. They stick out a little further than I wanted. Yeah, I measured/simulator, etc for weeks, and still messed up.
      03-31-2015, 08:46 PM   #6
Twix
Twix's Avatar
Drives: 2011 e91
I'm running 19x8.5 ET 27 in the front. No issues with the lowered suspension.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      04-01-2015, 12:07 PM   #7
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
These turned out to be NOT what I ordered, but I liked them anyway. They were supposed to be gloss black, with machine face with clear coat. Niche calls this color black with dark tint machine face.
This' what I ordered. I don't believe the wheels I got would look good on some trim lines, but my "no-line" black trim all around, they look good, IMO.
      04-01-2015, 05:15 PM   #8
improvius
Very nice! This is my current ride. I'll probably recreate this orange stripe on the Miro wheels to go with the Valencia Orange X1 I'm ordering.
      04-01-2015, 06:16 PM   #9
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Seems we have similar tastes. My previous car was a GTI, too. Like those Miros on orange.
      04-17-2015, 10:05 PM   #10
Mr_Jack
Drives: X1 35i M Sport
I just ordered Apex Arc 8 in 19x8.5 et20 and 19x9.5et22. Should sit flush with the fender. Between 3 tire sizes.
225/40/19 & 255/35/19
235/40/19 & 265/35/19
245/40/19 & 275/35/19
We will see sooon!
      04-18-2015, 09:00 PM   #11
Twix
Twix's Avatar
Drives: 2011 e91
Those wheels may stick out past the fender by about 1/4".
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      04-19-2015, 12:12 PM   #12
Mr_Jack
Mathematically, the rim itself "should" sit flush with the outer most point of the fenders. Lets see! I get them on Thursday. I can't wait.
Going to end up with 225/40 255/35 Hankooks.
      04-21-2015, 11:28 AM   #13
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
I have ET35 front, with 245, and they are flush. I chose ET20 for the rear 9.5s, and wish I would have gotten the ET35 on the rear also. They DO stick out a bit, and I may bite the bullet and get another set of rear wheels with the proper offset if they continue to bother me. You have slightly narrower tires, so it should be acceptable, but they will extend beyond the fender line. Since installing my new wheels, I notice a slight visual camber now on the rear.
      04-21-2015, 08:53 PM   #14
Twix
Twix's Avatar
Drives: 2011 e91
OH yeah! I love the noticeable camber of my rear wheels. It's nice and subtle, but still able to see it.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      04-21-2015, 09:06 PM   #15
PleaseAdvise
///M-Sport
Drives: 2014 X1 2.8 M-Sport LMB on CR
That is a good kind of mistake, looks AWESOME!
Want to see Hi-res Pics of my 2014 LeMans Blue X1?
http://imgur.com/gallery/WTGCm
      04-22-2015, 08:22 AM   #16
Mr_Jack
Do you have a photo of how far they stick out?
'15 E84 X1 35i M Sport
MPI DME Flash - K&N drop in - MPI Chargepipe - Oil T-stat valve - ETS 5" I/C - N54tuning 3.5" downpipe - catless mid section - Dinan 135i rear exhaust - Apex ARC8 18x9/10(255/295 tires) - H&R Sports - Bilstein B6's - F3x M Performance brakes
'02 E39 530i 624whp/558ft-lbs @23psi
      04-22-2015, 12:22 PM   #17
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Here's a rearend shot.
And thanks, PA.
      04-24-2015, 04:28 PM   #18
improvius
Hmmmmm.....
      04-24-2015, 09:05 PM   #19
Mr_Jack
Here are the new wheels installed.
19x8.5 ET20 225/40/19
19x9.5 ET22 255/35/19
Rear is dead flush. Front is about 8mm in from the fender edge. Very happy.
      04-25-2015, 06:45 AM   #20
BeEmVe
Drives: '14 X1 x28i M-Sport
Nice, for some reason it also most looks like the car is lowered a bit??
Not to completely thread hijack but now much of an issue does one need to worry about with fitting over brakes? The wife likes the look of bmw's 350 wheel that is also an 18x8 et30. I have been toying with the idea of mounting a set with summer tires.
I know going smaller diameter can be an issue with fitting over the brakes but what in general even when the diameter is the same??
      04-25-2015, 09:09 AM   #21
improvius
Looks great. I guess I didn't realize how far inset the stockers are.
      04-25-2015, 02:56 PM   #22
Mr_Jack
Yes, its on H&R Sport Springs.
Those wheels should fit fine.
