      01-19-2013, 11:26 PM   #1
bmw5406spd
Passionate About Cars
17
Drives: 2013 Bmw X1 35i X-Line
need some wheel info help
Going to be buying a set of 19 x 8.5 front and 19 x 9.5 rear, what is good offset to use so they sit good on wheel well, thanks
using 235 35 19 front or 245 35 19
265 30 19 rear or 275 30 19
which tires size is good i don't want car to dart all over road
2013 Bmw X1 35i, X Line, Midnight Blue/Terra, JB4, BMS CAI, BMS Down Pipe, H/R Sport Lowering Springs, M5 Style 19 Inch Wheels, Midnight Blue/Terra
2009 Bmw 135i Sport Coupe, Red/Tan, JB4, PLM Down Pipes, BMS CAI, Carbon Fiber Rear Splitter
      01-20-2013, 10:35 PM   #2
Endless Details
Drives: 2015 328i Touring F31 Xdrive M
Do you plan on lowering your ride height at all?
      01-20-2013, 11:18 PM   #3
bmw5406spd
17
yes, h and r sport springs i think 1.5 rear and 1.3 front?
      01-20-2013, 11:35 PM   #4
nospam
Drives: 2015 Alpina B6; 430i; X5 40e
What are your OEM sizes?
      01-21-2013, 12:10 AM   #5
bmw5406spd
17
they are the factory rft 18 inch that come on the x line, i think they call them y spoke wheels
      01-21-2013, 01:05 AM   #6
nospam
My recommendation is not to move to a staggered setup (you don't have performance control).
What are your goals...just to pimp your ride?
Past: E36 325i, E39 540i, F46 323i (AA tuned), E82 3.0NA, E84/F30 N20 BMS Stage 1, E70 X5 N55, F06 N55
      01-21-2013, 06:54 AM   #7
Endless Details
A safe setup would be around 32mm front and 35mm rear... I am lowered 3" and run 14.5mm front 19x8.5 225/35 and 22.5mm rear 19x9.5 265/30 but I had to do fender work to get the fitment I wanted.
      01-21-2013, 10:33 AM   #8
nospam
Forgot to ask, sDrive or xDrive?
      01-21-2013, 11:46 AM   #9
bmw5406spd
17
35i awd
      01-21-2013, 01:53 PM   #10
nospam
I have had H&R sport springs on the E46 and Eibach ProKits on the E39. Unless you are planning to track or auto-x I would personally choose the progressive Eibachs over the H&Rs. Lowered ride was more comfy on the Eibachs while the H&Rs were more predictable/sporty but harsher. I ran Koni FSD shocks with both setups. Both were superior in every way to stock sports package.
If you really feel you need a staggered setup even though you don't have M Sport (it does look more aggressive), I would try and match the settings of the M Sport 19s.
