      04-13-2016, 05:50 PM   #1
sktmithy
Australia
Drives: X1 20D Manual 2010 xDrive
Alternative to Z4 rear Bump Stop
Hi,
I Australia my local dealer wants $99.00 each plus 3-5 weeks delivery from Germany for Z4 rear bump stops. I was hoping someone might have come across a more readily available alternative.
It is to be used on my newly acquired B6s with H&R springs.
Thanks,
      04-13-2016, 07:55 PM   #2
PrematureApex
Just trim your stock stops like everyone else?
Also, probably a good idea to trim the front Bilstein stops as well.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      04-13-2016, 07:58 PM   #3
PrematureApex
http://e84.xbimmers.com/forums/showp...&postcount=105
Just lop off the first segment, that way you'll still be able to use the stock dust covers.
No bottoming them out at all.
      04-13-2016, 09:57 PM   #4
sktmithy
Australia
So to be clear you trimmed the end section that sits against the chassis?
Ta
      04-14-2016, 07:10 AM   #5
PrematureApex
Ta
No, trim the first segment of the softer lower end that the dust boot attaches to. You can still slip the dust boot over the (new) lowest segment after trimming.
      04-15-2016, 02:35 AM   #6
sktmithy
Australia
Awesome thanks I am glad I confirmed
      04-15-2016, 11:50 PM   #7
sktmithy
Australia
For those "on car trimmers", are there any tricks to getting the plastic protector back over the bump stop once cut?
Mine are fighting me all the way.
      04-17-2016, 06:51 AM   #8
PrematureApex
Once you cut the bottom off, it requires a good bit of force to get the cover over the next ridge as it's not perfectly sized. Never tried it on the car, but that would certainly make it harder.
Why didn't you trim it when you had it out? Or did you just do the springs (in which case, you'll probably pull it apart soon enough when you see how bad the stock shocks/struts are on the H&Rs )?
      04-18-2016, 02:29 PM   #9
mwtrogus
Drives: 2014 X1 35i
I cut the rear bumper stops while they were still mounted in the car... was switching winter wheels back to my Volks for the spring/summer so it only took a few minutes.
It's very easy to cut the bump stop and remove... then you'll need to cut 2 half inch slits on opposing sides of the dust boot. I used a Drexel with cutting wheel and it went well. The slits help you to squeeze the boot to expand it and clear the larger bump stop size.
      04-18-2016, 02:33 PM   #10
PrematureApex
^^^Good idea.
I basically had to put all of my weight on the stop to get it into the boot after trimming...so doing that on the car would be very, very hard.
      04-20-2016, 03:45 PM   #11
themishmosh
Drives: BMW X1 xDrive35i
I just kept twisting. Once a part of it snugs in, the rest of it will twist in by friction.
      04-27-2016, 06:48 AM   #12
sktmithy
Australia
I got them by placing a zip tie around the bump stop budge and sliding the cover on. Once they are most of the way on I cut the tie and slipped the cover over.
