      07-30-2013, 01:59 PM   #1
zero-2-sixty
Drives: X1 xDrive35i
BMW maintenance schedule
Hey all, my 2013 X1 35i has passed the 10k mile mark. I called BMW service and they told me my vehicle has to hit 15k miles before I get an oil change under the maintenance program. Is this right? I thought I read that BMW revised its oil change interval to every 10k. Since the X1was new, I took it at 5k miles and changed the oil at the dealership. I know some disagree as to when to change out but more frequent oil changes cannot be bad. Are they telling me right?
      07-30-2013, 02:55 PM   #2
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
Supposedly for 2014 models on. Here is the thread that discusses the change
http://e84.xbimmers.com/forums/showthread.php?t=868302
I'd be interested to know what the difference is(according to a dealer or BMW) that makes the 2014 models more needy/deserving of frequent oil changes
      07-30-2013, 03:42 PM   #3
Lucky13
Lucky13
It's all based on CBS or condition based service. My X1 has 8,450 miles on it and it says 3,100 more miles (11,550) or 7/14 which would be 2 years. It won't let you go pass 2 years and same for brake fluid. Basically you get screwed changing the oil at 5,000 miles. Your dealer is probably going by what your car is telling him. By changing the oil at 5,000 you probably extended the change you would have got at 12,000 + to 15,000+. The Mini I traded said over 16,000 miles before it was calling for an oil change. Anybody that bought a 2013 or prior just got screwed by BMW. They don't change the oil intervals unless they are seeing some wear issues due to the turbo heat. Chances are they decided not to take the financial hit to make it retroactive and the PR nightmare admitting that the engine oil should have been changed earlier on all turbo gas engines.
      07-30-2013, 03:57 PM   #4
Red Bread
Drives: Smog machines
In the US, you qualify for a low mileage oil change every year if you don't hit the mileage based (which as Lucky13 correctly stated, is based on fuel consumption, not set miles) distance. If you paid for the 5k mile change as a supplemental service and didn't have them reset the indicator, your dealer should still provide the "free" annual oil change for you.
As stated, the new oil change interval only applies to 2014 and newer models, many of missed the cuts, even with identical motors. Fortunately for us, we put about 9k miles a year on ours, so it gets a covered oil change every year and under even the new mileage guidelines.
      07-30-2013, 05:10 PM   #5
Lucky13
Lucky13
Nowhere in any written material does it say 12 months so good luck on getting the dealer to change the oil for free. It never even says 24 months but the cars computer is set t 24 months.
      07-30-2013, 05:20 PM   #6
Red Bread
Certainly possible, but the three dealers I've used in California and Texas have all done it for each of our BMW's, with no prompting from me.
      07-30-2013, 05:30 PM   #7
Lucky13
Lucky13
You got oil changes on your X1 or previous BMW's at 12 months? BMW has changed the program several times, I've bought 14 BMW's over 18 years. I got screwed by Mini when they said oil had to be changed at 12 months and then they wouldn't pay for it when I had it done. 3 months later BMW changed Mini's program due to complaints. In all cases its good to have good relationships with your dealer. The problem with the Mini was my wife had to drive 125 miles to get to the Mini dealer. Needless to say I'll never buy another Mini due to the dealer in Charleston, SC.
      07-31-2013, 07:03 AM   #8
HBWT
HBWT's Avatar
11
12 months is correct and has been this way at least since the 1999 E46. I've had several 12 month changes on multiple BMWs and even a MINI.
      07-31-2013, 12:40 PM   #9
Lucky13
Lucky13
Again that's nowhere in writing and if you read the other thread and the bulletin that went to dealers it says the new 10,000 mile 12 month replaces the current 15,000 24 month program.
      07-31-2013, 12:56 PM   #10
Teutonic
Teutonic's Avatar
I change my oil in my BMW at 10.000 km regardless what BMW says.
Once was free, once I paid because I didn't reach what they say.
For me is very important to change the oil to keep the car in top notch shape.
Especially when it is working at -30, -40 Celsius...
      07-31-2013, 03:29 PM   #11
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
Indeed, for anyone parking their car in subzero temperatures, the wear is going to be several times as high as when the oil is warmer, and the oil and filter should be changed more often.
This is perhaps even more important for the first oil change, where there's more chance of tiny metal particles being caught in the oil filter.
No matter what BMW says and pays for, I highly recommend changing more often if you live in a colder climate, drive hard, or both.
      07-31-2013, 04:09 PM   #12
zero-2-sixty
Does this new service interval that BMW switched too apply to our X1? I did not see our model listed unless I missed it. Is this announcement on BMW website as I would like to take it to the dealer? Are there any differences between the N20 and N55 engines for 2013 and 2014 that made them apply this to 2014 vehicles only? It is not making sense this sudden action they made applied to 2014 models.
      07-31-2013, 06:20 PM   #13
eric9610
Drives: 2020 Telsa Model YLR
there have been no changes on the engines otherwise they would have changed the numbers on the models. N55=> N56 and N20=> N21. BMW is going to have quite a Class action lawsuit on there hands if damage happens under the 15K guideline.
2021 MYLR (c), 2016 MB E350 (c),2018 MB E300 (r), 2019 AMG GT63s 4D (r),2018 MB E63S (r), 2018 911T (r), 2014 X5M (r), 2013 X1 35i (r),2011 M3 (r), 2010 328i (r), 2008 M3 (r),2005 330ci (r), 2004 Lotus Elise (r), 2004 X3 (r),2002 330ci (r), 2002 Hummer (r), 2002 MB G500(r), 2000 Z8 (r), 2000 323cic (r)
      08-03-2013, 07:27 AM   #14
gvlbuckeye
Drives: 2014 Xdrive 28i MSport
I picked up my 2014 this past Thursday from the Performance Center. They spend over an hour going over EVERYTHING about the car. Our guy said oil changes were every 15,0000 miles.
      08-03-2013, 09:47 AM   #15
bimmerfile
bimmerfile's Avatar
621
Drives: 2019 BMW X2 F39
I put on LT 10K Kms (6K miles) on each my bimmers each year (my prior 2003 Z4, and the current 2008 128i) and my dealer has always provided a free oil and lub service every 12 months. I expect the same will be the case for my wife's X1..
2019 X2
      08-03-2013, 01:09 PM   #16
eric9610
the CBS has several variables and the milages changes based on time (days) and miles driven. Currently mine is due when i hit 11,000 as i will not drive close to the 15,000 preset milage. it is not Stated in any documents but the computer service millage on the car changes based on the Conditions.
