      06-10-2013, 04:36 PM   #1
bmwx3805
bmwx3805's Avatar
305
Drives: 14 cruze diesel and 2019 430I
My x1 has reached 34 mpg
I guess it is possible. Didn't think it was. But it is. I mainly do 90% interstate driving with a little stop and go. I was very surprised. Has anyone else reached the 34mpg mark? Just curious.
      06-10-2013, 04:47 PM   #2
annoyingmouse
Drives: bmw x1 xdrive28i
Xdrive or Sdrive? I think a few Sdrive drivers have done it.
My xdrive trip computer indicated 32 on a highway run with a tail wind, but the overall MPG for that tank turned out to be 29.
edit: Reset the trip average while coasting down hill for a quick 50+.
      06-10-2013, 05:09 PM   #3
soapman72
soapman72's Avatar
23
Drives: 2013 X1 M Sport, 2016 M4
35.5 on a trip to Knoxville from Nashville. 65mph cruise control.
      06-10-2013, 08:21 PM   #4
bmwx3805
bmwx3805's Avatar
305
I have s-drive
      06-10-2013, 08:26 PM   #5
bmwx3805
bmwx3805's Avatar
305
Thats really good. That will be my next goal. I'm just really surprised i was able to reach 34. The highest i have been able to achieve is 31mpg. So im thrilled.
      06-10-2013, 08:46 PM   #6
soapman72
soapman72's Avatar
23
You have to drive like an angel (a 90 year old angel) in order to acheive that kind of fuel economy. In my case, it helped that about 95% of the trip was on the highway. It is REALLY easy to destroy the average with just a few hard acceleration runs away from stop lights or up onramps. LOL!
      06-11-2013, 05:25 AM   #7
Naambezet
Netherlands
11
Drives: BMW X1 sDrive 20i
I have done as low as 6 L/100km, just drive slowly, around 100km/h and no hard accelerations.
But that is boring ass hell, so I'm mostly doing about 9L/100km
      06-12-2013, 09:11 AM   #8
bmwx3805
bmwx3805's Avatar
305
Well actually im 21. Not a 90 year old angel haha . But most of my driving is on the interestate and then a little stop and go sometimes 10% or less. But as far as my driving all i do is follow the speed limits. Thats it. But with that being said i have used the sport and manual mode a few times and its a blast but thats when the mpg's go into the sh*t hole. But overall my mpg's are good even when i don't use eco mode i average around 30.5-31mpg's.
      06-12-2013, 02:11 PM   #9
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
It's not necessarily hard accelerations that kills fuel economy.
It's regaining momentum that's the killer.
As long as your accelerations don't engage the turbo, it doesn't matter much whether you take 10 seconds to get to speed slowly, or 5 seconds to get to speed quickly and then coast for 5 seconds.
But if you brake and then have to go back up to the same speed, that'll cost you.
The bigger the difference in speed, the more fuel.
  • If you drive towards a red light and stop from 40 to 0, it will cost you a lot more gas than if you quickly brake from 40 to 20 and roll towards the light which goes green while you're still doing 20. Even if you are way behind all the other cars when it turns green. To save fuel, brake early, brake lightly.
  • If you try to maintain an exact speed, you'll use more fuel. That includes using the cruise control. It doesn't know that when going up a small slope, it's ok to drop 10 mph, because you'll regain it rolling down the other side. It doesn't know that you have to slow down for the curve coming up, and will maintain the speed until you have to brake, which is wasteful.
  • Wider turns allow you to maintain more momentum. It's the minimum speed you have at any point through the curve that'll cost extra fuel.
It's easy to get my 35i to do better than 28 mpg if I think "momentum", even if accelerating quicker than the average person does. But it takes always thinking ahead, and driving like that won't always make you friends on the road.
      07-23-2013, 10:18 AM   #10
elfhearse
CW5
elfhearse's Avatar
Drives: 14 x28iS/10 e91M/00 Z3MC
2014 BMW x28i  [0.00]
2010 328iT  [0.00]
Any access to non-ethanol gas? I know SC has quite a few no ethanol gas stations and the e0 should give a 3-4 mpg increase. (Based on my past experience with 318ti DD when our state switched from e0 to e10)
CURRENT:
10 328iT ZMP-6spd, 00 Z3 MCoupe, 76 2002 stg.2 5 speed
PAST: 96 318ti Cali, 03 325Ci, 00 Z3 M Roadster, 99 Z3 2.8 Coupe, 14 X128i M-Sport14 Z4 28i Sport 6-spd
      07-23-2013, 03:52 PM   #11
bmwx3805
bmwx3805's Avatar
305
Yes i do. There is probably about 3-4 gas stations within 10 miles of me that offer ethanol free gas.
      07-23-2013, 08:04 PM   #12
Lucky13
Lucky13
What part of Columbia are you at because the station I've always used is 10% ethanol? I'm in the Irmo area and always use the brands BMW recommends "top tier" but I'd switch in a second for better mileage and more power.
      07-24-2013, 07:15 AM   #13
elfhearse
CW5
elfhearse's Avatar
2010 328iT  [0.00]
REF No ethanol stations.... Check out. Www.pure-gas.org. Listings for each state
CURRENT:
      07-24-2013, 11:07 AM   #14
Lucky13
Lucky13
So the 3 stations near me all say 87 only for ethanol free. I usually but 93 so 87 is below what BMW recommends (89).
      07-24-2013, 08:50 PM   #15
elfhearse
CW5
elfhearse's Avatar
2010 328iT  [0.00]
I think the minimum recommended octane level is 91.... Personally. I would never go below 91 octane. Finding a 91 or 93 octane no ethanol is usually limited to gas stations that are near lakes , bays to service the marinas. ( marine engines hate ethanol. )
CURRENT:
      07-24-2013, 09:01 PM   #16
Lucky13
Lucky13
I live near a really big lake so that's why I have several stations with ethanol free but apparently boat owners like cheap gas (87).
      07-24-2013, 09:17 PM   #17
Grovsnus
Flight Lieutenant ≛
Correct. The manual says that you should not use lower than 89, but 91 is recommended.
They don't recommend 91 just to get you to part with money. When using 89, the engine will adjust to avoid knocking by delaying the ignition, which causes less complete combustion, and higher gas usage. So while it runs fine on 89, what you save at the pump, you lose most of by getting worse mpg.
Lower octane can cause more engine wear and earlier wear-out of the catalytic converter, which is why BMW recommends 91.
There's not much point in going much above 91, though.
93 is fine, but won't work better than 91 for normal driving. Above that is not recommended unless you have a tuned car and preferably changed intakes too.
      07-25-2013, 07:34 AM   #18
bmwx3805
bmwx3805's Avatar
305
I haven't personally used it in the bimmer. I did how ever use it when i had my 12 Volkswagen jetta and personally i saw a pretty big difference between gas with corn and using real gas. When i used real gas my jetta would get a good 4mpg jump. Anyways the hickory point gas station in irmo right down the road from Jim Hudson Toyota offers ethanol free fuel, as does city gas on bush river road right across from the wal-mart, then there is also the shell station on leesburg rd. But the hickory point station only offers from what i remember to be 87 octane fuel.
      07-26-2013, 02:39 AM   #19
Big Stew
Big Stew's Avatar
Drives: X1 Xline Xdrive 2.0 Diesel
You guys really need to lobby BMW to import more diesel engined motors, they may rattle a bit more but the mpg and torque more than make up for that !
      07-26-2013, 07:46 AM   #20
Grovsnus
Flight Lieutenant ≛
Your cars won't run over here, due to the crap quality high sulphur diesel we have.
And getting the contiguous 48 states to agree to impose quality restrictions on diesel so it doesn't ruin the engine of imported cars would be a neat trick. Especially given the powerful farming lobby.
So what we get are special US models, which don't sell well because in the mind of the average American, a diesel is still a slow, stinky and soot-spewing contraption. Never mind the evidence to the contrary.
      07-27-2013, 02:00 AM   #21
elfhearse
CW5
elfhearse's Avatar
2010 328iT  [0.00]
I watching Mazda to see how they make out with their Skyactiv Diesel in the US. No "blue" liquid adder required either.
Thank the EPA for low sulfer diesel and ethanol fiasco (and the corn lobby, etc, etc, )
CURRENT:
      07-27-2013, 08:43 PM   #22
bmwx3805
bmwx3805's Avatar
305
I really wish we could get them to bring more down here and just suit the engines to US diesel. I did get a chance to drive the X5 with a diesel and it was amazing.
