      02-17-2017, 05:20 PM   #1
vstolpner
Drives: 2019 F39 X2 m35i
Brake pad wear
Hi everyone,
So my car is getting serviced and I got a call saying that my inner pads are practically done when my outside pads are practically new.
The advisor said that this is a normal occurrence but is the first time I've ever heard of this happening.
Has anyone heard of this before?
Thanks in advance!!
      02-17-2017, 06:35 PM   #2
fiehlsport
Drives: '13 X1 xDrive35i
Interesting, I wonder if stuck slide-pins on the calipers could cause this? As a data point, my brakes (front and rear) did not wear in that fashion. It was pretty even before each set of pads were replaced.
      02-17-2017, 08:12 PM   #3
vstolpner
That was my thought as well. I want to chat with technician tomorrow and see what they say. I don't mind replacing the pads, but if something is wrong I would want that fixed...
      02-20-2017, 12:51 AM   #4
vstolpner
So finally got the wheels off and used my caliper to get all the measurements. Wanted to see if anyone has experience of this being normal or not?
Front right pad 6.3 inside / 7.9 outside
Front left pad 3.7 inside / 8.9 outside
Front left disc 7.4mm
Also, since I'm going to be replacing pads anyway, any suggestions? Anyone do any comparisons between OEM and aftermarket?
Lastly - the rotors are smooth but there are some ridges, so I'm wondering if I should be replacing them at the same time? Don't feel like shelling out an extra $150 if I don't have to.
Again, any recommendations or experiences would be great ... Thanks!!
