      12-11-2015, 03:59 PM   #1
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Realistic GVW limit?
I use my car daily to do local deliveries, and about twice a month it's a fairly large, heavy, load. Would a 2-4000 lb. load, in addition to my 230 lbs, be dangerous? The car handles fine, if a bit sluggish, and I don't drive aggressively when I have that size load. I'm planning on lowering springs/shocks in the spring, depending on their ability to work with the demands I place on the car.
      12-11-2015, 06:38 PM   #2
paradoxical3
I assume you are towing this?
      12-12-2015, 01:00 AM   #3
vstolpner
Drives: 2019 F39 X2 m35i
If you're carrying it inside the car then you're probably doing some damage as I think the car would be rated for at most five adults and luggage... So 1500-2000 lbs max.
If you're towing I've seen numbers around 1500 with a standard square bar hitch, and 4000 with a direct attachment similar to execuhitch. The main difference being the play in the square bar (I don't recall why this mattered).
      12-13-2015, 07:01 PM   #4
Mtpisgah
Drives: 2010 WRX & 2013 X1
I have pulled 3,000lbs a few times and it wasn't an issue, but I would not want to do it regularly. The car is sluggish and the brakes aren't sufficient. I don't think the car is built to pull that, regardless of what the manufacturer or anyone else might say.
Since you are in Pasco and if you are hauling wine, I will come help though and we can split the load. Especially if it is Cayuse or Figgins or Reynvaan or Rasa or....
      12-14-2015, 04:20 PM   #5
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
I make lots of deliveries to wineries, but no wine hauling. Yes it's inside the car, and consists of finished printing and apparel. I own a printing business, and the really heavy stuff is either shipped, or if local, I use a truck. I just hate driving a truck every day, so if it's deadlined; out I go in the X1.
      12-15-2015, 12:00 PM   #6
fw_fw
Freude am Fahren
fw_fw's Avatar
Drives: 18 X3 xDrive30i xLine Phytonic
2-4000 lbs INSIDE the car???? You are either overestimating the weight or stressing your car to unheard and undesigned levels.....
Current: 18 X3 xDrive30i
Past: 03 530i Sport | 06 330ci ZHP | 14 X1 xDrive35i M-Sport | 11 328i M-Sport | 98 M Roadster
      12-15-2015, 12:33 PM   #7
mcdanielvzw
mcdanielvzw's Avatar
144
1 x 10 ream box of paper is 50 lbs, so that would be a lot of paper inside the car. I believe a pallet of paper is 2000 lbs, and that's 40 boxes. I can't see fitting that much into an X1
      12-15-2015, 04:42 PM   #8
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Coated papers are quite a bit more dense, so I was estimating.. 16 med. boxes @ 30-40lbs. ea. Uh, never mind.....
      12-15-2015, 05:07 PM   #9
Red Bread
Drives: Smog machines
Note to future self. Do not shop used X1's.
      12-15-2015, 06:21 PM   #10
paradoxical3
Why not? I'll sell you one...great condition, completely stock, never driven hard or tracked.
      12-15-2015, 06:35 PM   #11
vstolpner
I don't see why not either... Not like i ever carried 2x4's, large plywood sheets, etc. in it...
Realistically speaking it is a wagon... If you weren't planning to carry stuff in it you would have bought a 3 series instead ;-)
      12-16-2015, 05:29 AM   #12
mcdanielvzw
144
Lol It's all good. I worked at an office supply store for years, and back then numbers were my thing.
      12-16-2015, 11:00 AM   #13
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
I'm afraid that my normal usage will be a real test of the X1's capabilities. All of my driving is in town, many stops, and often hard acceleration getting in and out of tight traffic. I never drive it on weekends, and it sits outside. It's difficult to ingress/egress with my fused spine (C2-T2) but I have that problem with almost every car.
