      11-27-2015, 10:19 AM   #1
mose121
Humanist
mose121's Avatar
Drives: F80 M3 ZCP/F31 330i M Sport
Running 4 rear wheels??? 255/35/19 on front 19x8 wheels? Wider rear tires possible?
Hi All,
Just curious if anyone is running 4, 19 inch rear style 225's all the way around. I would prefer to run a square setup with all 19x9's and probably 255/35/19's. Open to running spacers if necessary.
On a similar note, is anyone running 255/35/19's on the stock front 19x8 style 225's??? Looks like most 255's state 8.5 inches as the minimum wheel width. The stock 225/40/19 Pirelli's look like rubber bands and are pretty stretched creating an arched "skinny" looking sidewall. I want them to be more flush and squared off with the face of the wheel. I've noticed a lot of Pirelli's seem to look more stretched than Michelin's of the same size.
Specification Sidewall Radius Diameter Circumference Revs/Mile
225/40-19 3.5in 13.0in 26.1in 82.0in 773 0.0%
255/35-19 3.5in 13.0in 26.0in 81.8in 775 -0.2%
In addition, is anyone running wider rear tires than the 255/35/19's? Looks like you'd have to go pretty wide (a 295) if you wanted the same revs/mile...
255/35-19 3.5in 13.0in 26.0in 81.8in 775 0.0%
295/30-19 3.5in 13.0in 26.0in 81.6in 777 -0.2%
Any input is greatly appreciated. I went though all the existing tire threads and couldn't find anything on this specific information. Thanks!
