      05-08-2015, 09:47 AM   #1
pinkertonpunk
Drives: '19 M2 Comp, '08 Honda S2000
X1 Drivers side mirror adjustment?
Hey everyone. Just got our new 2015 X1 a week or so ago. Wondering if anyone else has this problem. The drivers side mirror doesn't adjust in towards the car enough for my wife and I. It is worse for her since she is shorter than me. It won't adjust in close enough to see even the edge of the car. I could live with it but I wanted to know if it was normal or not. Out 135is doesn't have this problem at all.
Thanks!
      05-08-2015, 10:04 AM   #2
improvius
Drives: 2015 X1 X28i
blind spots
If your mirrors are adjusted correctly, you shouldn't see the side of your own car.
      05-08-2015, 10:44 AM   #3
CSPM
CSPM's Avatar
Drives: 2014 BMW X1 S28
Take the car back to the service dept, there is a service bulletin regarding that issue. I can't seem to find it right now, it has been a year. It involves removing the mirror and modifying the bump stop to give you more range of motion. My wife and I experienced the same issue and after the mod, we are very happy...
      05-08-2015, 01:00 PM   #4
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
This is correct! You should ONLY see the side of your car if your head is held against the side window. This is so when you use your mirror(s) you will see where you are going instead of where you are. Simple concept but it takes some getting used to.
      05-08-2015, 03:29 PM   #5
CSPM
CSPM's Avatar
Found it. Service Bulletin # SIB 51 06 13 Involves moving the mirror bumper stop. I had originally reviewed it from the Bimmerfest forum back in 2013.
      05-08-2015, 03:34 PM   #6
pinkertonpunk
Is there a way to access these online? I would almost rather just do the bulletin myself if it was easy than take it in.
      05-08-2015, 08:03 PM   #7
ZIPNBYE
Let's save military ranks for those who earn it!
ZIPNBYE's Avatar
Drives: ...on the Ragged Edge
You should never be able to see the side of your own car while seated normally if your mirrors are adjusted properly.
http://www.caranddriver.com/features...id-blind-spots
Richard
2013 BMW M3 Individual -- Fire Orange (sold)
2013 BMW X1 xDrive35i M-Sport -- Valencia Orange (sold)
2011 BMW 1-series M Coupe (#205/220) -- Valencia Orange (sold)
2009 BMW 135i M-Sport Coupe -- Space Grey (sold)
      05-09-2015, 11:55 AM   #8
rrajbhan
Drives: 2007 BMW 335i Sedan
I ran into the same problem. I had BMW of Nashville look at it several times last year and they said they adjusted it many times but yeah the mirror doesn't go inward enough for me to see my door handles (what I'm used to). Finally I got the answer that I should adjust my mirrors like that. I've lived with it and now I'm OK with it. I noticed its worse the higher I put seat, too. I'm 5'7", BTW.
      05-10-2015, 02:14 PM   #9
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
Don't sit so far forward. Use the lever on the side of the steering wheel and pull it further out, and follow by moving the seat further back or reclining a bit. Then you should have no problems with the side mirrors.
      05-21-2015, 12:32 AM   #10
FrozenInCND
Drives: 2014 BMW X1
Why do people insist they need to see the side of there car? What are they looking for? YOU SHOULD NOT BE ABLE TO SEE THE SIDE OF YOUR CAR! By turning in the mirrors so far that you see the side of your car you greatly increase your blind spot. Sorry for my screaming, but I ride a motorcycle as well as my car and truck, and I have been cut off because when people check there mirrors they see the side of there car not what is in the middle of the lane.
http://www.theglobeandmail.com/globe...ticle15250793/
http://dev.seniordriving.aaa.com/imp...t-your-mirrors
Just because you have always had your mirrors incorrectly adjusted, doesn't mean you can't learn to use them correctly. Now that you know you are doing it wrong change before you kill someone!
