04-02-2015, 07:22 PM | #1 |
First time owner
15
Rep 156
Ugly yellow lights
Hi all I'm in the process of getting A 2011 X1 but it doesn't have xenons. I want to replace the standard halogens with something a bit whiter I know for the full and dipped beams I need H7s but what lights are used for DRL? Is it the dipped ? The manual isn't especially clear :-). Thanks. UK spec if that makes a difference.
04-02-2015, 07:31 PM | #2 |
Rep 545
Drives: x3 m40i
The DRL lights it your high beam at a lower voltage, hence the yellow.
Even if you replace them with a better bulb, at a lower voltage it be less white. Anyhow that is what we have in Canada as far as I know. Have a look further down in the forum, there is someone solving your problem. |
04-02-2015, 07:57 PM | #3 |
Rep 1,922
Drives: 2011 e91
Whatever you decide to do, please don't be that guy that gets an aftermarket HID kit and put them in that halogen housing only to blind on coming drivers. Nothing makes me more angry than that.
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
04-03-2015, 10:13 AM | #5 |
Rep 17
I've used blue dipped halogen bulbs in the past and are whiter but the light is poor.
They were cheap bulbs I bought though and I understand the more expensive Bosch or Osram ones are pretty good. Can't remember off the top of my head what temp I had, but I think it was 6000. Anything more than that and they leave white and look blue |
04-03-2015, 10:07 PM | #7 | |
Rep 675
04-04-2015, 02:36 PM | #10 |
Rep 17
It was 6000k bulbs that I had. They seemed to be the whitest without verging on blue.
http://www.autobulbsdirect.co.uk/Osr...FQbItAodUHQAIA Bear in mind though that this is simply a cheap solution for a whiter light, not a top-end solution. For the price though, worth a shot |
04-09-2015, 08:27 AM | #12 |
First time owner
15
Rep 156
Looked at a few options, and whilst trying to keep to a reasonable budget have decided to try MTEC super whites. Anyone have any experience of these?
Thanks
04-12-2015, 08:09 AM | #13 |
Rep 87
I used Philips Diamond Vision h7 5000K halogen on both high and low beams. The color on the low beam will be bluish white. The high beam is used for DRL and at a reduced output, so you won't get the full color out of it. DRL will be whiter but still yellowish so I simply disabled it from the iDrive settings.
04-13-2015, 06:34 AM | #15 |
First time owner
15
Rep 156
Thanks for that - I dont think I'll have to worry about DRL actually - theres no light sensor on the car, so my light options are OFF, Dipped or Sidelights.
Need to wait and see when I get it
05-11-2015, 04:52 AM | #16 |
First time owner
15
Rep 156
Things didnt work out with that particular car but everything for a reason because I found one with xenons - so will have ugly yellow angel eyes instead!!
I find the LUX option a bit pricey, although I may go down that route eventually.... Anyone else used white lights for the halo rings with any success?
