      06-25-2013, 02:19 PM   #1
Chrakaknox
Drives: X1 35i M-sport
275 width in the rear?
has anyone tried 275/35/18 or 275/30/19's on the rear yet? I'm looking into ordering aftermarket 18" or 19" wheels - still haven't decided. Most I'm looking at are 9.5" wide on the rear with a 35 offset. If a 255 width fits without much trouble, would the extra 20mm (.78 inches) cause any issues in the rear? BTW, I would be sticking with 225 or 235 in the front either way. Thanks in advance...
'14 Valencia Orange/Black X1 35i M-sport
BMS N55 intake
18x8 29et Black lightweight wheels w/ 235/45/18's
      06-25-2013, 07:43 PM   #2
soapman72
soapman72's Avatar
23
Drives: 2013 X1 M Sport, 2016 M4
I probably wouldn't go that wide in the rear. Although it would definitely look cool, all you will do is cause the vehicle to understeer more, and you definitely want to confirm that the O.D. of whatever front tires you pick match up exactly with the rear , or you risk causing issues with the AWD and ABS due to wheel speed differences.
      06-25-2013, 07:47 PM   #3
HotRodW
HotRodW's Avatar
Drives: 2013 X1 xDrive28i M Sport
You'll lose about 1/2" in overall tire diameter with either of those sizes.
      06-26-2013, 06:55 PM   #4
richb811
richb811's Avatar
455
Drives: 2020 G20 330i M Sport
265/35 is closer to spec, its within 1.1% of OEM spec.
285/30 is also better than the 275/35 but might be a tad wide for the fenders. It's also around 1% of spec.
I wouldn't recommend the 275/35 as it is going to screw with your X-drive system being over 2% out of spec.
      06-26-2013, 09:20 PM   #5
Chrakaknox
thanks for the info...
BMS N55 intake
      06-26-2013, 09:43 PM   #6
Chrakaknox
the 18" OEM spec is 26" diameter and the 19" OEM spec is also 26" or is it 25"? The BMW ordering sheet is confusing me, the upgraded 19 inch sizes convert to 25":
Front/Rear
225/35/19 255/30/19 25 in diameter
225/45/18 255/40/18 26 in diameter
BMS N55 intake
      06-27-2013, 07:09 AM   #7
richb811
richb811's Avatar
455
Front/Rear
Exact outside diameters I couldn't tell you.
These are percentages based off your OEM spec tire sizes and if you want your X-Drive to work properly, you are going to need to keep within 1%
      06-27-2013, 11:30 AM   #8
Chrakaknox
Oh, Ok, I'd always thought the most important number to stay closest to was the overall diameter and that's 26" for the standard 18" wheels on the 35i....but the upgraded 19" package you can order with the msport line converts to something like 25.1" which is a pretty big difference (approx. 4%)in my eyes.
BMS N55 intake
      06-29-2013, 02:05 PM   #9
soapman72
soapman72's Avatar
23
I wouldnt be too concerned about a slight increase or decrease in diameter as long as the front and rear still match perfectly. You can find the O.D. for various sizes/manufacturers on tirerack.com. Our tires in the factory size are EXACTLY the same diameter, so that is the way I would keep it. Even ABS braking performance will be affected by mismatching diameters.
      06-30-2013, 09:00 PM   #10
Chrakaknox
looks like 245/35/19 fronts and 285/30/19 rears at 25.8" diameter should fit the bill...
BMS N55 intake
      07-05-2013, 02:16 PM   #11
Chrakaknox
Wow, after doing more research on several sites, I'm surprised to find out that even in our stock 18" staggered sizes, there are many tire manufacturers that list their overall diameter as NOT exactly the same. I.e. 25.9 in, or 26.1 in, and not always exactly 26 inches for the same size. I didn't realize there was a slight difference in the same size from manufacturer to manufacturer. I always thought the tire would have the exact O.D. no matter who made it, as long as the size was the same....
BMS N55 intake
      07-05-2013, 02:43 PM   #12
Chrakaknox
ONLY the Conti DW's (out of 10 different max summer tires on tire rack) in 225/45/18 - 255/40/18 have the exact same diameter - 26.0 inches. So does 0.1 of an inch matter that much from front to back if it measures 25.9 inches? The other 9 out of the 10 tires do not match exactly.....
BMS N55 intake
      07-06-2013, 08:43 PM   #13
Twix
Twix's Avatar
Drives: 2011 e91
The reason for the slight difference in outer O.D. is the tread depth.
      07-06-2013, 09:50 PM   #14
Chrakaknox
I thought so too, however, I believe all 10 tires I researched were listed as 10/32" tread depth....
BMS N55 intake
      07-07-2013, 08:07 AM   #15
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
So does 0.1 of an inch matter that much...
it matters not in the least.
