      06-11-2013, 11:11 PM   #1
wantm135i
wantm135i's Avatar
Drives: x1 35i m sport
REMOVE ROOF RAILS how x1
i have seen several bmw x1 with out the roof rails and i would like to have the same look. How are the roof rails removed. Any pics any extra parts to be ordered?
      06-12-2013, 06:34 AM   #2
Endless Details
Drives: 2015 328i Touring F31 Xdrive M
I believe all the US models come with Roof Rails... To remove them you will need to drop the headliner to access the assembly hardware and you will need a new trim piece to go on the roof where the rails currently sit which would be from a country that had a no roof rail option. Not to sure how hard it is to source for the X1 but we did this on a 535xi wagon e61.
      06-12-2013, 10:04 PM   #3
wantm135i
wantm135i's Avatar
you own the white x1 lowered right wow its so nice. besides the rims and lowering the suv have u done an mods for power, iam getting ready to buy all paper work is filled out but holding because i want to make sure this x1 35i m sport can at least go to 100 in 12 sec and the 1/4 mile in13.2 or faster can it be done were iam not killing the motor and not spending crazy money like over 5000 is to much for me on add ons on a motor that is under warranty. thanks rob
every thing on net is of a stock x1 35i at track or chip mod but on dyno no real numbers moded on track yet
      06-13-2013, 06:34 AM   #4
skylineguv
Drives: 2015 Macan Turbo, Jet Black
I could have sworn someone, maybe paradoxical3 or CIWS, had run theirs at the track already.
      06-13-2013, 11:32 AM   #5
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
Dude don't take it off, as you can see it is alot of hassle doing that alone which could compromise the rigidity of the vehicle as well as your safety.
      06-13-2013, 11:44 AM   #6
Red Bread
Drives: Smog machines
Hehe, seriously? He's talking about the roof rails. As noted, you can get at the mounting hardware by dropping the headliner and then it's just a matter of getting the blanking plates and getting them painted and installed. Here's the diagram, but tracking down the blank plates will probably require using an EU parts supplier:
http://realoem.com/bmw/showparts.do?...19&hg=51&fg=20
      06-13-2013, 06:18 PM   #7
Teemo Panda
2013 BMW X3  [5.66]
It really depends who is removing it for you which in sense could make you or break you.
Just remember the X1 is new in the US so majority of the shops is not familiar with the car unless you pay your dealer for the labor.
      06-13-2013, 07:19 PM   #8
skylineguv
Unlikely to compromise the rigidity though. The X1 is available without the roof rails outside of NA.
      06-13-2013, 09:32 PM   #9
wantm135i
wantm135i's Avatar
thank vyou so much for info. i tryied to order the x1 35i m sport with out a sun roof no go, and in red cant do that either with out roof rails nope. since i cant have a m135i i thought i could at least build on close enough nope lol
      03-27-2016, 03:20 PM   #10
FrozenInCND
Drives: 2014 BMW X1
Ok this is a real old post, just wondering if you ever did get the rails removed? I would really like to do the same.
      03-27-2016, 08:47 PM   #11
vstolpner
Drives: 2019 F39 X2 m35i
I have seen a post on this before and from what I understand it's a rather involved process and there are issues with water leaking afterwards
      03-29-2016, 10:13 AM   #12
X1Denver
niner
Drives: 13 X1 Alpine Xdrive35i M
Uh, EVERY X1 comes with the holes for roof rails either way. the rail trim is replaced and the holes are filled with correct bolts with rubber grommets built on them.
I have all the parts if you want to buy them. I bought a different toy car to work on and dont have time for this conversion. Parts cost me $250.00
You can find what parts from realoem and then order from ECS or someone.
Then you can download the ETKA or whatever guide to show how to remove and install.
      03-29-2016, 10:14 AM   #13
X1Denver
niner
http://e84.xbimmers.com/forums/showthread.php?t=1151016
