      04-12-2016, 04:01 PM   #1
IslandTimes
Drives: 2013 X1 sDrive28i
X1 LSD Swap Possible?
Curious if anyone has tried or knows if it's possible to switch a limited slip differential into a rear wheel drive X1? I believe someone makes an LSD for the E90, could that swap in on our cars too?
      04-12-2016, 05:05 PM   #2
vstolpner
Drives: 2019 F39 X2 m35i
I imagine you could do something with M3 parts...?
      04-12-2016, 05:18 PM   #3
PrematureApex
Yup, not sure of the final drive of your car, or if you wanted to go with a shorter overall ratio...but generally speaking an E90 diff will bolt right up.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      04-12-2016, 05:26 PM   #4
PrematureApex
I'd call Quaife, I'm sure they could set you up. Probably have to read them off your current diff part number.
https://shop.quaife.co.uk/quaife-bmw...auto-328i-auto
http://www.realoem.com/bmw/enUS/show...diagId=33_1517
Realoem.com shows that you have the same diff as all of these cars:
PN:
33107591023
So anything for any of those will work.
      04-13-2016, 02:32 PM   #5
IslandTimes
Awesome, thanks for the help, I will reach out to them!
Does anyone know if the differential in the X1 is bolted or welded? I was searching E90 forums last night and several people were talking about the differential being welded somewhere?
