      04-06-2024, 08:44 AM   #1
bosstones
Drives: o_0
Suspension and Ball Joint Fun!
I'm at 92k and getting ready to replace almoat all suspension bits. The ball joint is the part that seems the most fun and I've got MAP, Kroil, and an air hammer ready to say hi to them.
Most of what I read on the boards deals with getting the ball joints out, not in. Assuming I run a scotch brite pad and slap some anti-seize in the knuckle cavity before putting in the new ball joint....do I still need a press? Aeema the Xi's are different and particular about tooling.
      04-07-2024, 08:33 PM   #2
NocheDeZippeh
NocheDeZippeh's Avatar
28
Drives: 2014 X1 35i M Sport
About a year ago I did a big front end and suspension refresh, and I didn't need a press to put the ball joints in. Just slowly and evenly go back and forth as you tighten the two bolts that secure it in place.
This video helped me a lot when I tackled this project (the ball joint section starts at 7:18)
bosstones1154.00
      04-08-2024, 06:44 PM   #3
bosstones
Drives: o_0
Thnx! I've watched this vid a few times. I think it was the only one that talked mich about the install.
      04-20-2024, 12:14 AM   #4
Allworth
Drives: X1 xDrive20d (E84)
+1 ball joints are easy to put on. I've used a fork type wedge and a hammer to get old ball joint out. Proper size fork (there are many sizes) will get it out easily.
1995 E34 525td auto • 2016 F30 320ed auto
