      09-16-2021, 10:51 AM   #1
lilysdad
7x BMW owner
Drives: 2012 X3 F25 xDrive35i
Excessive rear brake pad wear
I have 13k miles on my BMW dealer installed rear pads (54k to 67k) and am getting the red brake warning in the CBS indicating they need replacement. Doesn't this wear seem excessive? I'm baffled by this. Rotors are still original.
Thanks for any insight.
Present: 2012 F25 X3 Xdrive35i - Sparkling Bronze with Nevada Red-Brown Leather
Past: 15 E84 X1 xDrive28i Sportline, 07 E90 335i, 06 E90 330i, 01 E46 330i vert, 99 E46 328i
      09-16-2021, 05:18 PM   #2
Gamb1t
Gamb1t's Avatar
Pad based on the photo looks meaty. I think the brake wear counter wasn't reset after your last brake pad replacement job.
Maybe the sensor is faulty or wasn't installed correctly? I think you're supposed to replace the sensor during pad replacements.
      09-16-2021, 07:54 PM   #3
lilysdad
7x BMW owner
Thanks for your feedback. The sensor was replaced by the service tech when the pads were replaced so I will stop by the dealer to see what's going on.
      09-17-2021, 07:04 AM   #4
4_ring_circus
Drives: Corrado, Audi S4, X1 128xi
You do not need to reset the brake pad light, as soon as a good sensor is connected it will go away. Have you checked your front brakes?
That pic you posted of the pad, is that the wheel with the sensor? There are only two pad wear sensors one in the front and one in the back.
      09-17-2021, 09:37 AM   #5
lilysdad
7x BMW owner
Understood on the light in relation to the sensor. Not sure what I'm looking at in regards to locating the sensor. Here's pics of both sides up front with these pads currently at 15k. Ironically, the front pads only show 600 miles of life left per the CBS. 🤷*♂️
      09-17-2021, 10:45 AM   #6
4_ring_circus
The brake pad sensor will be on the inner pad, you could have a sticking caliper and the inside pad could be worn down. You could also have a faulty sensor.
Here is a good little tutorial on pad replacement, it shows the location of the sensor:
https://www.youcanic.com/guide/bmw-b...or-replacement
      09-17-2021, 12:30 PM   #7
cwickberg
Drives: X1 35i MSport Ultimate,
There is a procedure to reset the brake wear warning.
I recently did it on my Daughter's X1. I used my app to do it but there is a procedure that uses the trip rest button and the center display, not iDrive.
      09-17-2021, 12:55 PM   #8
4_ring_circus
Seriously? I have a 2012, and there is no procedure to reset the light. Maybe some of the newer models got stupider.
      09-17-2021, 06:14 PM   #9
cwickberg
https://www.youcanic.com/bmw-brake-light-service-reset-instructions
      09-17-2021, 06:35 PM   #10
0w40X1
Drives: 2014 BMW X1 s28i M Sport
I caught5 my rear pads with half wear at 25k miles, and replaced them. I couldn't get the untripped sensor to fit the pad, so I tied up out of way.
I accidently found out that the excess rear brake and rear tire wear was related when I put Posi-quiet ceramic pads on.
On my s28i it has very strong ediff for any takeoff. It locks one side which skids tire, then, the other.
Now my tires are wearing much closer on the new Michelin PS4S.
      09-20-2021, 04:21 PM   #11
Gamb1t
Gamb1t's Avatar
I do not believe a new sensor would automatically reset the computer. The sensor reset procedure is the same as the e90 3-series. Lots of youtube instructions to do that. Very simple. Alot of owners simply splice the sensor wires and tie it off.
However based on your idrive display, there might be other issues at play.
      10-04-2021, 10:39 AM   #12
lilysdad
7x BMW owner
Issue resolved
I wanted to follow up on my original post with results from the dealer. The sensor wire was indeed tripping to due rotor corrosion which wore down my rear pads prematurely. I was told I just needed pads when I replaced the rears at 55k two years ago. If I had replaced the rotors at the time I'm sure my pads would still be fine. Instead, I got to replace the pads and rotors 13k later to the tune of $700. Also had them adjust the idrive warning for my front pads since they were still showing plenty of life left yet the idrive was displaying only 800 mi left. Thanks again to those that responded.
      10-13-2021, 06:59 PM   #13
alpinec1984
Drives: 2018 X3 M40i Alpine White
sounds more like a sticking caliper to me, not sliding correctly on the slider pins.
      10-14-2021, 06:58 AM   #14
4_ring_circus
That's what I said a few posts up. It is either the sliders or the piston inside the caliper that are starting to seize. Unless the tech working on your car actually fixed one of these issues you will be back for another $700 brake change soon.
Usually once corrosion get in it start progressing faster.
      10-26-2021, 06:26 PM   #15
PABMSJ
Drives: 2014 BMW X1
BTW, how much did you guys paid for front brake changes (including new rotors)?
