      06-13-2020, 02:59 PM   #1
citizenboyo
citizenboyo's Avatar
Drives: BMW E84 28i X1
Square setup = Stuttering problems with acceleration?
Hey guys, I recently bought new wheels off of facebook, brand new continentals and its a squee setup of 245/40 19" I believe their 19x9. I moved from the factory 225/40? 255/45? by 18" wheels, and I have been experiencing stutter issues with my car, also my car has the tire pressure sensor light because of the new wheels. Has anyone run a square setup on the xdrive X1? And is it something I have to code in or is it entirely the wheels fault that I am stuttering
      06-13-2020, 05:22 PM   #2
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
I run a square setup with both my summer (245/45 17) and winter (225/50 17) tires. With 225/50 17 being what the car came with.
I'm guessing it is the wheels, not the tires. What wheels did you get and are you sure they are the correct bore size (72.6mm)?
This post sent using 100% recycled electrons.
      06-13-2020, 05:23 PM   #3
bucketfoot
bucketfoot's Avatar
What did you for TPMS sensors? Did you take the ones off your old wheels?
I would try doing a TPMS reset.
      06-13-2020, 05:26 PM   #4
citizenboyo
Not too sure what wheels I got, but theyre 19" 245/40 All round, I dont think theres a tpms on my wheels, i was digging around and people say the canadian X1's use the ABS and Americans get TPMS
      06-13-2020, 05:31 PM   #5
bucketfoot
bucketfoot's Avatar
I would check for a part number on the wheels.
When I do a google image search on your photo it comes up as possibly an X5 wheel. The X5 has a different bore size and would need hub rings.
      06-13-2020, 08:15 PM   #6
citizenboyo
When I do a google image search on your photo it comes up as possibly an X5 wheel. The X5 has a different bore size and would need wheel rings.
Ok Thank you, what is bore size exactly?
      06-13-2020, 08:29 PM   #7
bucketfoot
bucketfoot's Avatar
The size of the hub. If you pull off a wheel and look at the round part of the rotor in the middle, this is the hub.
An X5 wheel has a bigger hub than the X1. so it will have a loose fit and will shake and slip some.
The top image here (ok the second image) shows this:
https://www.discounttire.com/learn/h...vs-lug-centric
      06-15-2020, 09:22 PM   #8
sudermatt
Drives: 2015 X1 35M
I'm running 245 45s on sportline rims. Haven't noticed anything.
      06-16-2020, 10:37 AM   #9
0w40X1
Drives: 2014 BMW X1 s28i M Sport
So, the fix is to take wheels off and find the right hub centric ring for the new wheels.
Most wheels are close, but slight different in the bore.
      06-16-2020, 07:29 PM   #10
jarsdad1
Drives: 2011 535i, 2015 X1 3.5
Not for nothing, but are your tires inflated correctly?
      06-16-2020, 07:30 PM   #11
citizenboyo
Theyre all at 35 psi, not too sure if i should inflate the backs to 38psi because it came factory staggered.
      06-16-2020, 07:35 PM   #12
bucketfoot
bucketfoot's Avatar
I still think it is the wrong hub/bore size and that you need to get the proper hub rings ASAP.
If this is the issue and you continue driving the car you are going to start damaging things.
      06-17-2020, 05:42 PM   #13
citizenboyo
So I found the serial code, its BMW 6 794 692, SKU is 36-11-6-794-692, Style 367. But I cant find the bore/hub size anywhere which is odd.
      06-17-2020, 06:11 PM   #14
bucketfoot
bucketfoot's Avatar
OK it looks like a Style 367 is the correct bore size (72.6mm)
      06-17-2020, 06:14 PM   #15
bucketfoot
bucketfoot's Avatar
Looks like the 5/6 series these were from use a larger thread size lug bolt (M14 x 1.25 vs M12 x 1.5).
You may be getting slippage on the smaller bolts. The taper on them probably is not large enough to solidly hold them.
      06-17-2020, 06:35 PM   #16
bucketfoot
bucketfoot's Avatar
You really need to go to a good tire shop ASAP and have them look at everything.
      06-17-2020, 06:49 PM   #17
citizenboyo
Ill book an appointment right away!
      06-19-2020, 07:25 PM   #18
citizenboyo
Just came back from the shop, I got it rebalanced, it was off balance and on one of the rear wheels theres 2 bends in the rims on the back, going to get that fixed. Swapped the bent rim to the other side and thats the cause of the stuttering and where i feel it. Thanks again! All lugs and bore sizes check out!
      06-19-2020, 07:34 PM   #19
bucketfoot
bucketfoot's Avatar
      10-20-2021, 09:54 AM   #20
Botlfed98
Drives: X1
can you elaborate on the studdering? Did it do it thru all of the gears? Mine seems to do it in 3rd gear or higher...
      10-23-2021, 10:57 AM   #21
4_ring_circus
Drives: Corrado, Audi S4, X1 128xi
OP had wheel balance issue not engine stuttering.
