      02-28-2011, 07:43 AM   #1
simon025
Australia
Drives: BMW X1 xDrive 20d
Do you manually switching off the engine when waiting in the traffic light?
I wonder how many of you manually switching off the engine when waiting in the traffic light?
My X1 has auto transmission so it doesn’t have the automatic engine stop/start feature. Most of my trips are in Sydney city and the traffic is slow. I switch off the engine on a traffic light if I know I have to wait for a while; I found that does keep the fuel consummation low. I wondering anyone of you are doing the same thing?
Thanks
Simon
      02-28-2011, 08:05 AM   #2
manicm
Drives: X1 sDrive18i
regardless of transmission, if I'm waiting say longer than 2 minutes then I would switch off.
      02-28-2011, 11:34 AM   #3
Gatekeeper
Gatekeeper's Avatar
France
11
Drives: BMW 320d Security
Ditto.
Traffic lights in normal traffic flow sounds a bit pushing the concept though, but since a S&S manual would switch off, I suppose it does make sense from an emission standpoint.
Now to save a few cents worth of gas ? I dunno... Driving a Beamer and cutting your engine at every traffic light to save a dollar by the end of the month sounds a bit tacky...
"Let our manners distinguish us from our enemies, as much as the cause we are engaged in"
      02-28-2011, 11:59 AM   #4
jmtm
jmtm's Avatar
Belgium
14
Drives: mini cooper
Hi Simon
If you've not the stop and start system, is it not a problem for the car to manually switch off the engine ?
Racing is in my blood. A. Senna
      02-28-2011, 12:33 PM   #5
Gatekeeper
Gatekeeper's Avatar
France
11
Originally Posted by jmtm View Post
Hi Simon
That is the question Simon is asking.
      02-28-2011, 12:55 PM   #6
jmtm
jmtm's Avatar
Belgium
14
Drives: mini cooper
The question of Simon was how many person switch off the engine manually no?
      02-28-2011, 02:19 PM   #7
nathan35
Drives: X1 sDrive18d
But the question's worth asking anyway: is the automatic start/stop doing exaclty the same to the engine as maunually switching the engine off, or is it somehow more harmful to do it yourself.
For those who do manually switch the engine off, please note however that:
- you lose power steering and especially power braking when the engine is off (important e.g. when you're staying in a traffic jam on a slope);
- the stopped engine may cool, or the battery may be used by the onboard electrical equipments beyond a point where the fuel economy is worthwile.
The automatic system controls all these things and re-starts the engine when necessary.
      02-28-2011, 02:54 PM   #8
jmtm
jmtm's Avatar
Belgium
14
Drives: mini cooper
thank you that's the answer to my question.
      02-28-2011, 03:54 PM   #9
Gatekeeper
Gatekeeper's Avatar
France
11
Exactly.
The S&S will stop the engine regarless of the stopping time, maintaining several features such as air con or heat.
It can't be bad to switch off an automatic (or a manual without S&S for that matter) when you know for sure you'll be standing for several minutes, but it doesn't make sense at every traffic light for a few seconds.
It also means you need to revert to N or P to crank the engine again, which defeats somewhat the purpose of an "automatic" transmission !
      02-28-2011, 07:15 PM   #10
alexmcred
alexmcred's Avatar
Ireland
12
Drives: 318d GT M Sport
The other thing is unless the engine is suitably heated your actually using more fuel as the engine is not at it's peak operating temp.
One of the conditions for s&s is engine temp
      03-01-2011, 03:05 AM   #11
nathan35
Exactly. The S&S system stops the engine only when the conditions are such that it makes sense to do it.
      03-08-2011, 04:17 PM   #12
Kres7787
Kres7787's Avatar
14
Drives: BMW X1 sD 18d JB
You need to wait about 2 secs after you press the ... clutch pedal? ... for the car to kick back in. After the S&S system shuts the engine down. I found it a bit weird since I can't _immidiately_ continue the driving, but it's still an overall pleasing feature x) just need to get used for the slight delay.
It took the car abouts 5 minutes of driving to start using S&S as the needed temp was reached. It was abouts 10C outside.
      03-08-2011, 05:15 PM   #13
alexmcred
alexmcred's Avatar
Ireland
12
By the time you have the gear selected the engine should be ready to move off. Takes a bit of getting used to but I am used to it now and find no delay between engine re- starting and moving off
      03-09-2011, 02:55 AM   #14
Gatekeeper
Gatekeeper's Avatar
France
11
2 seconds seem excessive...
Basically you depress the clutch wich cranks the engine while simultaneously engaging first gear.
It takes slightly longer than I could do it on a non S&S if I had to move in a hurry, but most times it's not significantly slower either, and I'm still the first one to move when the light turns green.
      03-09-2011, 03:27 AM   #15
mario486
Mario
mario486's Avatar
Scotland
26
Drives: X1 XDrive 2.0d, Mini Cooper
Thanks
Simon
Nope, never do it for some of the reasons mentioned above. In addition I am not convinced its a good thing on the auto either as its not been designed for it. Not too sure on the detail but if the S/S system is the same type of thing as I have on my Mini there are a whole bunch of things added because of the S/S system, ie
Stronger battery
Stonger starter motor
Regenerative braking (charges battery)
Also the Mini's system is quite fast. On my auto X1 I would have to push the start button, then put it in D. Too slow for a fast get away.
I always switch it off on the Mini anyway as I don't like it but I can say in all honesty that I cannot notice any measurable difference in consumption.
"Do or do not, there is no try!" - Master Yoda
"Always in motion is the future" - Master Yoda
"Truly wonderful, the mind of a child is" - Master Yoda
"There is no passion to be found playing small - in settling for a life that is less than the one you are capable of living" - Nelson Mandela
      03-09-2011, 04:42 AM   #16
Kres7787
Kres7787's Avatar
14
Yeah though as the engine restarts you almost need to aim to grab the gearshift without missing it due to all the heavy vibrations on it. But yeah no big deal really. Just something to get used to. As I said, I like the idea of S&S. So no problem.
      03-09-2011, 04:46 AM   #17
tompak23d
tompak23d's Avatar
Drives: iX M60
In my drivers manual I can read that if the stop is longer than 30 sec. it is worth shutting down the engine.
      03-09-2011, 04:57 AM   #18
Kres7787
Kres7787's Avatar
14
Maybe he just doesn't like to have to refill often. Takes some time to do it that I would understand. Ecology? Nah since it's xDrive. x) but yeah saving on gass on a xDrive 20d Bimmer... Hard to chew. Surely unreasonable worrying. Or is it?
      03-09-2011, 07:00 AM   #19
mario486
Mario
mario486's Avatar
Scotland
26
My X1 is in the same CO2 tax band as my Mini and has better fuel consumption. Thats green enough for me
PS: And probably one of the most efficient production 4x4's on the planet!!
      03-09-2011, 07:26 AM   #20
Kres7787
Kres7787's Avatar
14
Yes for sure. I haven't really researched other cars in similar categories thouroughly but from what I found out and heard, yeah BMW engines are top class. Fast and efficent! xDrive systems as well. Gonna make my new order this or the next week when we're on that topic!
Yeah but still there is no explanation for turning the engine off on each traffic stop... If it was a cheap car...
      03-09-2011, 07:30 AM   #21
Douggie
Drives: BMW X1, X3
I'm not a big fan of this because I feel this adds strain to the car, both mechanically and electrically. Like in all machines and electronics, start-stop/power cycles are the most damaging.
      03-09-2011, 08:14 AM   #22
Gatekeeper
Gatekeeper's Avatar
France
11
It does. But lower emissions is the name of the game now.
