      06-24-2022, 01:48 AM   #1
bmwownerwww
Drives: BMW x1 e84
BMW X1 2013 acceleration hesitancy + Radiator light flashing + revs stuck high
Hi all,
Today I had a journey with some hills and noticed
  • acceleration hesitancy - jumpy, lumpy, jerking.
  • Check Engine Light flashing has now come on when this happens.
  • revs stuck when this happens.
      06-24-2022, 04:30 PM   #2
bmwownerwww
Drives: BMW x1 e84
Originally Posted by bmwownerwww View Post
Hi all,
I purchased this recently.
Any ideas on a scale of 1-10 how screwed I am?
I am going to get a mobile mechanic to come inspect ASAP.
Update 25/06/22
Have run an OBD scan and Error code P0301 Engine Misfire Cylinder 1 is coming up.
Now researching.
      06-25-2022, 12:39 AM   #3
bmwownerwww
Drives: BMW x1 e84
Update 25/06/22
Now researching.
Changed cylinder 1 spark plug, same issue. Cylinder 1 misfire.
Tomorrow going to try swapping ignition coil to see if problem moves cylinder.
      06-25-2022, 07:31 PM   #4
bmwownerwww
Drives: BMW x1 e84
new spark plug yesterday
new ignition coil (misfire moved to cylinder 2 when doing swap test)
took it out for a run worked fine.
Then second run and runs like a dog and "check engine" light flashing.
checked with updated scanner again cylinder 2 misfire P0302.
Changed ignition coil in cylinder 2 - fault codes now gone.
Runs much better, no lumpyness, hesitancy, wobble tickover.
will test more and see what it does next lol.
