      03-03-2011, 09:36 AM   #1
melts
Singapore
9
Drives: X1 sDrive18i
Parking fan
Hi folks, has anyone got the parking fans to work?
I tried but unsuccessful. What i thought was this.
You set the timer (there are 2?! I wonder what for) and it's suppose to blow cool air into the cabin.
So technically if you are going to park for 2 hours, I should think you'd set the timer for like 1.5 hours, so that it will count down from the time you leave the car and 1.5 hours later it would blow cool air into the cabin.
I tried numerous times and it doesn't work. Can someone tell me how please?
Thanks.
      03-03-2011, 10:33 AM   #2
mario486
Mario
mario486's Avatar
Scotland
26
Drives: X1 XDrive 2.0d, Mini Cooper
Thanks.
I have used it a few times but difficult to explain. Basically you set the start and off time (ie first time is start, second is stop). You then use the return arrow (on the non iDrive car) to set. If set correctly the fan indicator light stays on when you take out the ignition key. Oh, and it only works for 1/2 hour so not to drain the battery. It is also just a fan, ie does not use the aircon or heater.
"Do or do not, there is no try!" - Master Yoda
"Always in motion is the future" - Master Yoda
"Truly wonderful, the mind of a child is" - Master Yoda
"There is no passion to be found playing small - in settling for a life that is less than the one you are capable of living" - Nelson Mandela
      03-07-2011, 06:56 AM   #3
melts
Singapore
9
Tried. But no success.
      03-07-2011, 07:17 AM   #4
Pepe79
Red Devil
Pepe79's Avatar
Drives: X1 20d xDrive
what is that?
      03-07-2011, 09:34 AM   #5
aris
aris's Avatar
Greece
Drives: X1 xdrive 23d
i do not know that feature in x1 ..give us details if x1 whith out idrive suport that!!
      03-07-2011, 03:03 PM   #6
mario486
Mario
mario486's Avatar
Scotland
26
Originally Posted by Pepe79 View Post
what is that?
It's a feature of the ventilation system that allows you to set the fan to come on at a pre-defined time for up to 30 min. I have used it a few times when I am at the shops to run the fan before I get back to the car. Unfortunately in the UK we do not have the auxiliary heater option but it can use a bit of residual heat of the engine to warm the car slightly.
I don't have iDrive either so Its done through the radios controls. Not well explained in the manual. I think though that you need to have the auto climate control option but could be mistaken.
      03-09-2011, 05:10 AM   #7
tompak23d
tompak23d's Avatar
Drives: iX M60
It is only for ventilation. Not any heating or cooling, it just blows fresh air, and only through the "ventilation grills" (sorry, donīt know the english word) in the dashboard.
      03-09-2011, 05:57 AM   #8
melts
Singapore
9
Mine doesn't have iDrive so it's controlled using the radio controls.
Tried this.
(1) Press menu
(2) Select "parked"
(3) You will see two timers
(4) It has four options; reset, recall, hrs, mins
(5) here's what I did please cue me in if I did it wrong - press 1 hr and 30 mins if you expect to come back to the car in 2 hrs time
(6) press the return button
(7) stop your engine and remove your key
(8) you should see a fan logo on your aircon even after you removed your key
(9) then it should start it's countdown to 1 HR and 30 mins
Tried that. Return to, still, a warm car?
      03-09-2011, 05:58 AM   #9
melts
Singapore
9
Originally Posted by tompak23d View Post
It is only for ventilation. Not any heating or cooling, it just blows fresh air, and only through the "ventilation grills" (sorry, donÂīt know the english word) in the dashboard.
Yeah, it just blows air. Not cool air. So perhaps that's why I don't noticed any difference.
      03-09-2011, 06:14 AM   #10
melts
Singapore
9
I literally fingered through the entire OM but couldn't find this?
      03-09-2011, 06:47 AM   #11
mario486
Mario
mario486's Avatar
Scotland
26
There is a half page or so in the separate manual I got to explain the radios controls. As you say nothing in the OM itself.
On a side note I have BMW UK investigating the fitting of a Webasto Parking Heater to a X1. The one I am looking at heats the interior as well as the engine block using a small furnace fitted in the engine bay. Runs on diesel/petrol out of the tank.
      03-09-2011, 07:40 AM   #12
aris
aris's Avatar
Greece
Tried this.
(1) Press menu
(2) Select "parked"
thank you! i will try that and give you details soon!!!
