      05-19-2016, 06:10 PM   #1
Akvaristu
Drives: 2012 X1 xDrive 28i
Unhappy 2012 X1, may need a new turbo (oil leak)
Hi,
I got an oil leak problem coming from around the turbo.
I purchased a 2012 BMW X1 28i xDrive one month ago and got a bad luck : there's dark smoke coming from the exhaust on every cold start. So I took the car to a good indie BMW mechanic to have it checked and that's what he found : There's an oil leak around the turbocharger and it's coming from either the oil line or both the oil line and the turbo.
Work estimate of 7 hours (87.50$CAD/h).
My question is, should I take a chance and replace only the oil line for 50$ a piece (and potentially needing to replace the turbo later, paying the 7 hours of work again) or should I replace both parts at the same time ? I was quoted 2750$ for a new turbo.
Thanks for your input!
Akvaristu
(long time lurker, first time poster)
2012 BMW X1 xDrive 28i - Space Gray - 99 000 km
      06-09-2016, 10:40 AM   #2
X1Denver
niner
Drives: 13 X1 Alpine Xdrive35i M
the oil LINE would not leak into the turbine housing of the turbocharger causing black smoke at start up.. the seal in the turbo is bad.
rebuild or buy a new turbo..
      06-09-2016, 02:19 PM   #3
improvius
Drives: 2015 X1 X28i
This is God's way of telling you to get a bigger turbo.
      06-09-2016, 04:58 PM   #4
Shock96
That was a hell of a thing...
22
Drives: 2013 xDrive 35i M Sport
The Hexon turbo upgrade is about 1950 for the unit.
Pure Turbos sells a re manufactured one all balanced for $695.
