      06-07-2016, 01:20 PM   #1
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Motiation needed
I've had a Burger module for about three months, and I've run out of excuses, not to install it this weekend. If anybody has a JB4, and DIY'd the install, are there any surprises, or extra parts needed? TIA, Dave.
      06-07-2016, 01:22 PM   #2
PrematureApex
Burger publishes install instructions...very easy to install. Should take you between 30 and 60 minutes first time around.
http://www.burgertuning.com/instructions/n55_stage1.pdf
How have you waited so long...
Map 5, after a couple of adjustment pulls on 93...
That's three months of massive power gains you've been missing out on...
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      06-07-2016, 01:33 PM   #3
neverdone
Drives: X5, 335, Ford Lightning, 63 me
Ya it's pretty easy. Mostly clips and some screws. The hardest part is clipping the boost solenoid, it's in a weird spot.
It'll take you 2 minutes as opposed to 30 seconds for the other clips lol tapping into the DME is no big deal either once you open it up.
Good luck man, you'll wonder why you didn't do it so long ago.
      06-07-2016, 04:30 PM   #4
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
We only get 92 here, and I only buy from Chevron, so would map 5 work for me as well?
Forgot to mention... one of the reasons for my reluctance, is my neck is fused from T2-C2, so I move like a zombie now.
It's supposed to be cooler this weekend, so that, and the fact there's no visitors, should help.
      06-07-2016, 04:52 PM   #5
neverdone
Sorry about your neck issues. Map 5 is fine, however, it will increase your neck issues lol
      06-07-2016, 06:19 PM   #6
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
What's map 5 again? I've been running map 1 this whole time.
      06-07-2016, 06:29 PM   #7
PrematureApex
Autotune. On 93, at decent ambient temps even with cats, it will make more power than map 2. On E85...different league.
IMHO, skip map 1 all together and just run map 5.
      06-07-2016, 06:53 PM   #8
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
I got catless downpipe and muffler delete. I always put in 94 so ill give map 5 a try. Thanks!
Edit: I also have an N20, does that make a difference?
      06-07-2016, 07:00 PM   #9
PrematureApex
I got catless downpipes and muffler delete. I always put in 94 so ill give map 5 a try. Thanks!
If you have a catless downpipe (only one of them!), you should already be on map 2. But yeah, go with 5.
Potentially more power than map 2, and the piece of mind that it's constantly adjusting to octane/ambient conditions/etc. so you don't get caught out by a tank of bad gas, etc.
      06-07-2016, 07:13 PM   #10
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
Why do I keep typing that lol. But yeh ill give it a shot thanks!
      06-08-2016, 11:05 AM   #11
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Is it true that you can't run E85 without changing the fuel system?
      06-08-2016, 11:19 AM   #12
PrematureApex
You can run a few gallons per tank everything else being stock with the JB4 on map 1, 2 or preferably 5 (big gains).
Anything more than say, 20% (so about 3 gallons), and you should add the BMS flex fuel wires, allowing you to safely run higher concentrations.
Above 50%, and I think some cars will start to reach the limits of the stock fuel pumps.
      06-08-2016, 12:07 PM   #13
neverdone
Definitely if you're looking for big power out of it, you might as well spring for the flex fuel wires and a better fuel pump.
      06-10-2016, 03:50 PM   #14
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
No, I just have an occasional need for acceleration. Damn the pain!
      06-12-2016, 09:35 PM   #15
fiehlsport
Drives: '13 X1 xDrive35i
Mine and my friend's N55 JB4s came with the FF wires already as part of the harness. Yours might too.
No need for a different fuel pump until you start messing with upgraded turbos.
We run 4-5 gallons of E85 for a full tank of petrol and these cars absolutely rip. Just remember to set FF to 70 in the software if you got the USB data cable. If not, you probably won't be messing with E85 anyway.
      06-13-2016, 05:31 PM   #16
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
Lol im kinda in a similar boat. I've been beating around the bush with ordering my JB4 for my x35i.
I assume everyone has already done upgraded charge pipe?
| 3-IM | AA Headers | Eurocharged Stage-3 | BMW PI |
      06-15-2016, 09:05 AM   #17
mcdanielvzw
mcdanielvzw's Avatar
144
I haven't yet, but will for my birthday or father's day (dad to cats, hah).
      06-15-2016, 02:38 PM   #18
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
I'm still running stock charge pipe and it's running good.
Will upgrade it soon though.
      06-15-2016, 04:48 PM   #19
PrematureApex
Nope, stock chargepipe on both my N54 (90k miles) and N55 (30k miles).
Don't hesitate...you'll love it.
      06-16-2016, 01:50 PM   #20
fiehlsport
Stock chargepipe here with no issues as well, I've seen up to 19psi consistently.
