      08-30-2014, 08:33 PM   #1
Blackmsport
Drives: BMW 320i 2007 and 120i 2006
X1 Xdrive25i N52 engine oil leaks
My car
2011
Xdrive25i
N52 3L engine
24,000km
Less than 16,000 miles
and it develops some oil leaks
a few drops every night on the floor
anyone experienced this sympton
Thanks
      09-02-2014, 03:28 PM   #2
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
N52 is famous with it's leaks. Could be motor oil from oil filter housing, or oil pan, or valve cover. Usually those gaskets fail over time.
Are you sure it's oil. It might be windshield washer fluid.
I recommend stop by the e90 forum. You'll find very useful information there.
      09-02-2014, 04:52 PM   #3
GTony
Australia
28
Drives: 2015 X3 F25 XDrive 28i M Sport
Hi Blackmsport,
Have you been able to have a good look around your (clean first) engine and other areas.
When was your last Service.
Have you phoned or taken to the dealer and asked them.
You would be close to running out of Warranty or have you already run out.
On a different note, a 6 cylinder X1 in Aust. isn't that common. If your into Modifications, the USA People on these threads are doing some ones.
