11-26-2013, 07:48 PM | #1 |
Rep 9
Cold air coming in through the dash
Does anyone else notice this? When at highway speeds on a cold day I noticed that cold air flows through the left side of the steering column, hitting around the area where the cruise control is.
The X1 can be up to normal operating temps with the heat on and I feel that cold air coming in there. Put your left hand near the cruise control feeling towards the dash and feel for it. |
11-26-2013, 09:07 PM | #2 |
Rep 1,922
Drives: 2011 e91
Haven't felt it. Did your foam fall out?
11-26-2013, 11:22 PM | #3 |
Rep 9
Thanks. Not that I'm aware of. Just noticed it this week. After 7k miles, you think I'd have noticed it before, but I hadn't. Check the next time you're on the highway and it's cold out. Brrr. Adds to the chill.
11-27-2013, 12:58 PM | #5 | |
Rep 2,350
Your CD is spinning too fast. |
11-30-2013, 07:05 PM | #6 |
Rep 9
OK. It happens when it's real cold outside, in the neighborhood of under 20 degrees F (-6 C) and highway speeds. Held my hand to the left side opening where the steering column enters the dash. It was cold air for sure. I don't feel it in the 30 degree F range (-1 C).
Car was at operating temperature and I mixed up the air vents from floor to dash to front vents and combinations of the three and none. This was not related to the fan or heater at all. Just blowing in the wind (pun intended). |
12-02-2013, 02:23 PM | #7 | |
Rep 330
12-31-2014, 01:09 PM | #8 |
Rep 202
I have the exact same problem. from the left side and tried closing all the vents and everything. You can only feel it during cold days. Planning to take my car to the dealer to have this checked.
Z4 M coupe with Super Sprint exhaust and X pipe, RPI Scoop, AFE air intake, ESS tune, DINAN 4.10 Limited Slip Differential, OEM CF spoiler.
M3 E92 Coupe with DCT, Akrapovic Evolution exhaust, ESS tune, DINAN 3.62 Limited Slip Differential, OEM CF performance parts. 1M Coupe... Loving it |
