      04-13-2017, 04:30 PM   #1
Royleblue
England
9
Drives: BMW X1 18d Sport
Screen Wash Issue
I am having problems with my front screen wash. When I pull the lever you can hear the pump working but very little screen wash comes out. I first though it had run out although I didn't get any warning, but I have filled it up.
Anyone else seen this.
      04-13-2017, 06:31 PM   #2
Gamb1t
Gamb1t's Avatar
Check the nozzle is not covered in gunk or bug. You can fix that with a needle.
      04-14-2017, 03:38 PM   #3
Royleblue
England
9
Hi Gamb1t
It is all four jets that aren't working. There is some water coming out but with very little pressure. There must be a blockage somewhere but it is hard to trace the route of the pipes.
      04-14-2017, 09:09 PM   #4
Njerts
Drives: x3 m40i
Does the rear washer work if you push the stalk forward?
      04-16-2017, 04:19 PM   #5
Royleblue
England
9
Yes. Not sure if that is just the screen wash left in the pipe though.
I was hoping to check for any blockages today but we had typical Easter Sunday weather - rained all day.
      04-17-2017, 12:40 PM   #6
kiloTHREE
Drives: '13 xDrive28i
Urh, I just found out I have the opposite issue. Fronts work, rear is dead.
Same as yours, I can hear the pump but not juice.
I'm tearing into mine tonight.
      04-20-2017, 10:27 AM   #7
kiloTHREE
I was confusing the wiper motor sound with the pump.
After further investigation my pump for the rear is kaput.
$40 bucks and some time, we are good to go!
      04-21-2017, 02:36 PM   #8
Royleblue
England
9
They don't make things easy, do they?
The pipes from the bonnet disappear into the wing, and the only part of the bottle visible is the spout, so I haven't been able to check for blockages.
There seems to be some pressure because when you pull the lever some fluid comes out, but after that it's just a trickle.
      04-21-2017, 02:49 PM   #9
kiloTHREE
It's a lot of work, but I would dig out your washer reservoir and just try blowing on the connection to see if it's blockage or the pump.
      05-11-2017, 02:34 PM   #10
Royleblue
England
9
Took it into a local (non BMW) garage. Cleaned the pipes out. £42 job done.
