      08-06-2017, 12:17 AM   #1
Xdrive35i2014
Drives: X1 35I
XHP for those of us with the 6AT transmission
Thread update: As of 2018, XHP works for E84 X1 35i!
Hey guys,
Did any of you get it to work? I am getting a TCU not compatible error message. I thought all ZF 6AT transmissions from BMW are the same...
Update from xhp ��
Hi Henry,
the later X1 used a TCU generation similar to that in the 8HP units. We only support the earlier X1 35i versions at the moment, sorry.
Regards
      08-06-2017, 11:44 PM   #2
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
Originally Posted by Xdrive35i2014 View Post
Hey guys,
Update from xhp 😭
Hi Henry,
Regards
Very interesting find. They indicated to me that it was available. There tune needs some refinement anyways so better to wait.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      08-07-2017, 08:51 AM   #3
mwtrogus
Drives: 2014 X1 35i
I ran the full TCU testing for Clemens(XHP guy) back in June. He reviewed the trans file and then activated the XHP for X1 35i use. He said it would work with no issues. Was expecting it to be comped for all the time I spent helping him out, but he didn't come through. I have a newer Alpina version and it works very well, figured I'd let the bugs get worked out on the XHP for a while before I make the purchase.
X1 35i M-Sport, Pure Stage 2 turbo w/ inlet and outlet, 7in intercooler, Fuel-It PI and pump, Jb4 w/MHD, XHP, custom catless exhaust, KW V1, Volk's and everything else...!
      08-07-2017, 11:51 AM   #4
X1Denver
niner
Drives: 13 X1 Alpine Xdrive35i M
There is tons of info on the E90 forum.
I have the Alpina and it was the greatest thing I bought for my car.
      08-07-2017, 01:50 PM   #5
Turbod
Turbod's Avatar
I have had stock, Alpina, and XHP stage 3 on my 335i. Stock was smooth and very well setup but was a bit sluggish, Alpina was a great improvement in shift speed when using M mode but was completely worthless in D mode, shift logic is not as good as stock. XHP made D mode driveable again but was far from ideal. With different throttle inputs the shift behavior isn't as dialed in as stock. Although the shift speed and firmness in M mode were improved it feels clunky and inconsistent.
Ideal setup for me would be a stock D mode, stage 2 or 3 S mode, and a modified version of the current stage 3 M mode.
2023 G80 M3 xDrive
      08-17-2017, 06:32 AM   #6
Jitin02
Drives: BMW x1
I am wondering if either of alpine or xhp voids warranty ? like cracks up ecu etc?
      08-17-2017, 02:09 PM   #7
Turbod
Turbod's Avatar
If you took the car in with a transmission flash that was not what it had from the factory I would not expect them to cover any repairs. Now if you're asking if it can be detected if removed I am not sure. You can always go ask xHP.
2023 G80 M3 xDrive
      08-24-2017, 08:23 AM   #8
E30_Crazy
Drives: 2014 X-Line 35i
Hey guys,
Update from xhp 😭
Hi Henry,
Regards
Judging by your username, you've got a 2014, same as me. Dang, I was just getting serious about buying the xHP flash. Guess I'll wait for bugs like mentioned above.
      08-29-2017, 02:34 PM   #9
mwtrogus
Drives: 2014 X1 35i
Just as info here...
I was able to use XHP trans flash a few days ago.
The backup went well and then the flash of Stage 3 loaded with no issues.
I have a 2014 X1 35i w/ the ZF 6speed.
Seems to perform very well and all drive modes have differences from the Alpina flash that I have used for a few years.
Turbod395.50
KGun192.00
      08-30-2017, 12:01 AM   #10
Turbod
Turbod's Avatar
Do they have the tune broken up into large turbo and stock turbo for the X1? If so, which one are you running?
I have the large turbo flash on the 335i and you can tell them mean big single. 3rd and 4th gear hang on until 2,700 rpm under light throttle.
2023 G80 M3 xDrive
      08-30-2017, 12:36 AM   #11
Turbod
Turbod's Avatar
Originally Posted by RBT-Tuning View Post
The dealer is unable to detect xHP. Flash to stock is 2 minutes, with xHP remaining installed.
Found this in the xHP thread.
2023 G80 M3 xDrive
      08-30-2017, 12:38 AM   #12
Xdrive35i2014
Drives: X1 35I
did xhp updated their software to include the x1 35i??? wow i got to try it. Can i flash xhp with JB4 installed switched to Map0?
      08-30-2017, 07:16 AM   #13
themishmosh
Drives: BMW X1 xDrive35i
Their FAQ says JB4 needs to be completely removed. Map0 doesn't cut it.
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
      08-30-2017, 02:08 PM   #14
Turbod
Turbod's Avatar
I removed the can bus wires on the JB4 when I flashed my 335i and that worked.
2023 G80 M3 xDrive
      09-13-2017, 09:18 PM   #15
Xdrive35i2014
Drives: X1 35I
I just plugged xhp to my car but it says my tcu is not supported. How did u get it to work?
      09-13-2017, 11:27 PM   #16
Turbod
Turbod's Avatar
I have two vehicles. My 335i is flashed and my X1 is stock. Even though the stock transmission tune is a little sluggish I wont update the tune on it until the stock turbo is running more than 15 psi or a larger turbo is installed. The drivability on the stock tune is just better than any current flash options.
***EDIT***
I just checked and it says my car's TCU is not supported.
2023 G80 M3 xDrive
      09-13-2017, 11:55 PM   #17
Xdrive35i2014
Drives: X1 35I
***EDIT***
I see. I got a bit confused there haha. I should really be quoting mwtrogus...
How did you get around the TCU not compatible error message on XHP?
      09-14-2017, 07:18 PM   #18
mwtrogus
Drives: 2014 X1 35i
The XHP trans flash has been great, the latest v1.4 stage 3 that I loaded today made some changes for the better. The manual downshifts are crazy from 3 to 2 with high Rev match blips.
I have also unlocked my DME and am running MHD, JB4 flash and the burbles are pretty crazy! I'm pretty much straight piped with no cats so it's pretty loud.
Get a good cable, make sure JB4 is in map 0 and connect it to see if supported. Then make sure you have a battery charger on for the backup and flash. It's so much better than Alpina
      09-14-2017, 09:03 PM   #19
Xdrive35i2014
Drives: X1 35I
Omg sounds awesome. I have been emailing back and forth with Clements and he said he will add my X1 tcu to the compatible list!!!! I cant wait!
Turbod395.50
      01-23-2018, 02:57 PM   #20
darkrom
darkrom's Avatar
Drives: 135i
I worked with the developer today and was able to flash my 2014 X1 35i.
Initial impressions are really good, but I want to give it a couple of days before a review. Very helpful developer and extremely supportive of his work.
      01-23-2018, 03:20 PM   #21
hooligan_G01
Space Shuttle Door Gunner
hooligan_G01's Avatar
6430
Drives: 2022 X3 M40i BG/Taco Red
Did you have the Alpina flash before or simply stock?
      01-23-2018, 08:07 PM   #22
mwtrogus
Drives: 2014 X1 35i
I tried a couple of the Alpina flashes before XHP.
XHP is much better all around and allows full customization if you want to. The shift points, smoothness and logic is great in D, DS and M
