      01-07-2021, 09:39 PM   #1
dirtydontlisten
Drives: Bmw x1
2014 x1 adding subwoofer
Step 1)
Buy this plug in play harness https://technicpnp.com/product-category/x1-e84/
2) connect the harness to factory amp on left side of the trunk remove liner
3) only one wire needed run to amp beside rca cables from that plug in play adapter a remote wire.
4) connect positive wire into battery and amp
5) connect negative wire to bolt on right side truck..in right truck liner.. and connect to amp.
6 ) connect speaker wires and done.
Amp hides perfect under trunk liner.
      05-06-2021, 02:30 PM   #2
shossein73
Drives: 2014 BMW X1 xdrive
Remote wire
Hello, i am trying to do the same as you but i am having an issue. Where did find or connect the remote wire for the amplifier.
thank in advance.
      05-07-2022, 10:59 PM   #3
Botlfed98
Drives: X1
thank in advance.
the Technic harness provides it....
