      09-26-2014, 08:12 AM   #1
Kennyboy
Drives: 2014 X1 Xdrive 28i
Halogen H7 high/low beam
Just a reminder, when upgrading the stock H7 halogen bulbs, don't forget to buy 2 pairs/4 bulbs lol. The medial/inner bulbs are for the daylight/high beam function, and the lateral/outer bulbs are for the low beam function. All four bulbs are 55 watts H7. I made a dumb mistake and ordered only 1 pair last time lol. I just double checked the part catalog on Bmwfans.info, all 4 bulbs are identical.
      09-26-2014, 08:18 AM   #2
squishy
Zimbabwe
153
Drives: 2014 Ford Mustang GT
Thanks for the tip!
      09-29-2014, 11:21 AM   #3
Shredjim
Drives: 2014 x28 X1
So Kenny - what were the results you experienced? What bulbs did you upgrade to, and how much brighter are they?
      09-29-2014, 12:03 PM   #4
Kennyboy
Since I only bought one pair of bulbs (BMW high performance), which is made by Philips, I decided to put it on the low beam (outer), since it is more useful than DRL and high beam. So far I have had them for 10 month. These lights seems to offer better distance rather than major improvement over brightness on the low beam. The lights are somewhat whiter than the stock halogens, but still kinda yellowish. I am looking into changing the bulbs again soon, possibly Philips Diamond Vision H7 5000K bulbs. This time I will order two pairs.
      10-01-2014, 08:00 AM   #5
Kennyboy
BTW, because when turning on high beam, the low beam also stays on; if you only have one pair of upgrade bulbs, putting it onto the low beam also helps with the high beam function.
      10-13-2014, 11:55 AM   #6
Kennyboy
Installed 2 pairs of Philips Diamond Vision H7 on both high/DRL and low beam. Love the effect. HID quality white color with a hint of blue from the blue colored bulbs. The DRL lenses even appeared blue from the reflection of the blue colored bulbs when the car is turned off. Love them. Let's see how fast they burn out.
      10-14-2014, 09:05 AM   #7
Kennyboy
I want to add one more side note, the Diamond Vision 5000K will still appear to be slight yellowish white on DRL setting, since DRL setting share the same bulb as the high beam, but gets a reduced output. So I guess the bulb is not putting out 5000K when used as DRL, but it is a lot whiter than stock still. The low beam appears to be blueish even at day time.
      10-14-2014, 09:24 AM   #8
Twix
Twix's Avatar
Drives: 2011 e91
Your guess is correct, the 5000k temp will only be reached with full voltage. Since the DRL cuts voltage to 6 or 9V, you'll only get a portion of that heat. Some bulbs also have a second filament in the same bulb at the full 12V, but with less windings to make for less output.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
