      07-28-2019, 11:29 AM   #1
darkrom
darkrom's Avatar
Drives: 135i
Improving ride quality at 100k miles
I'm at 107k on my x1 35 and it's starting to feel like sloppy steering with some vibration in the wheel and seat at 80+. The shocks and struts seem fine for now until I upgrade them probably next year.
I run brand new pilot super sports. I had the steering rack replaced under warranty at 45 or 50k miles.
What else can I look into replacing to get some of that new car smoothness and tightness back. As well as higher speed stability. Not trying to go crazy with it but I want to make it a joy to drive again. Just not sure what parts to start with.
      07-29-2019, 09:40 AM   #2
mreric
Drives: 2015 BMW X1
check all bushing for wear,
your control arms might be worn.
      07-30-2019, 06:38 AM   #3
darkrom
darkrom's Avatar
Drives: 135i
Thanks will do. Anything else to check while in there? I think motor mounts and transmission mounts are probably okay but I'll see if I can get them checked out eventually.
      07-30-2019, 12:00 PM   #4
mreric
Drives: 2015 BMW X1
the other thing that can affect handling beside all the suspension bushing is alignment. if you have not done that in a while it might not be a bad idea.
      07-30-2019, 04:24 PM   #5
05X3lover
Drives: '15 Dark Gray X1 AWD
I agree with the alignment recommendation. also hopefully the tires are balanced since they're new? If not they can cause a lot of shaking. Why was the steering rack replaced at such a low mileage, btw? Factory defect?
      07-31-2019, 05:38 AM   #6
darkrom
darkrom's Avatar
Drives: 135i
Yes it was making a clicking noise. They likely just needed to tighten some bolts but they replaced it and I won't say no.
The alignment is perfect I had that done recently too.
Thanks
      08-08-2019, 06:37 PM   #7
sudermatt
Drives: 2015 X1 35M
Motor mounts and shock mounts are liquid filled. My BMW guy said these should be replaced around 80 or 90k.
