      07-16-2019, 05:57 PM   #1
akay1
Drives: 2015 BMW X1
How to update 2019 maps in navigation
I would first like to thank you for your help, Ian fairly tech savvy but i can't figure this out. I have downloaded the new premium 2019 maps for North America. I have unzipped the files and put them on a USB.
For some reason when I plug the USB into the dash nothing comes up. I went to the software update option but still got nothing, it says no USB recognized.
Is there something that I am missing here? If you are aware of any step by step instructions i would really appreciate it!
Thank you very much for your help!
      07-16-2019, 06:26 PM   #2
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Use the USB in the glove box
This post sent using 100% recycled electrons.
      07-16-2019, 06:54 PM   #3
akay1
Drives: 2015 BMW X1
I read that online but i don't believe the 2015's have USB in the glove box, i think the only one is on the center console.
      07-16-2019, 06:55 PM   #4
akay1
Drives: 2015 BMW X1
Also just re-formatted it to ExFat since my Mac won't let me do Fat-32. I am attempting to unzip the files again so it will take a while, will let y'all know if that works.
      07-16-2019, 07:33 PM   #5
bucketfoot
bucketfoot's Avatar
It's in there, it's just a little hard to find the first time. You have to use this one.
      07-17-2019, 05:41 PM   #6
akay1
Drives: 2015 BMW X1
You were right sir, in the glove box on the top left. I tried it there too with the new format but still no luck....
      07-17-2019, 05:58 PM   #7
bucketfoot
bucketfoot's Avatar
Everything I've seen says it has to be FAT32.
      07-18-2019, 08:29 AM   #8
BillACK
Drives: 2014 BMW X1 xDrive28i
It took a while for my '14 X1 to recognize the flash drive (maybe 5 minutes). Might just need to leave it in longer. Oh, and I was able to format the drive FAT32 on my Mac. Good luck!
      07-18-2019, 03:43 PM   #9
Chicone
Drives: 2015 X1 X35i M-SPORT
Don't use USB3 flash drives. USB2 work.
-Steve
2015 BMW X1 35i MSport // BMS Intake
      07-18-2019, 05:25 PM   #10
akay1
Drives: 2015 BMW X1
Thanks for the tips, i will try to leave it in when i go for a drive and see if it loads. I am using a USB2 flash drive right now and was able to format it to FAT32. Hoping it will work, will let y'all know!
Hey BillACK did you plug it into the center console or glove box?
      07-18-2019, 08:32 PM   #11
bucketfoot
bucketfoot's Avatar
I'm not BillACK but it has to be the glove box
      07-20-2019, 10:03 PM   #12
akay1
Drives: 2015 BMW X1
Thank you everyone for your help, was able to get updated to the new maps. And 100% right plug it into the glove box. If you need any help give me a shout out and will help out!
      07-21-2019, 12:32 PM   #13
akay1
Drives: 2015 BMW X1
As a side note when updating the software you have to plug it into the center console, it won’t let you do it from glove box.
Just glad to have the map and software update done and completed!
      08-07-2019, 03:59 PM   #14
darkrom
darkrom's Avatar
Drives: 135i
Where did you buy the map upgrade. I understand you need a code to upgrade correct?
      08-09-2019, 10:59 AM   #15
BillACK
I found the maps files online at a "pay what you want" site and bought a "lifetime" code off of Ebay. Once I finally left the flash drive in the glovebox port long enough to activate the upgrade process, everything worked great!
      08-09-2019, 01:14 PM   #16
akay1
Drives: 2015 BMW X1
Hey I purchased the map and the FSC code online, it does take a couple minutes for the car to recognize the USB.
