      08-18-2020, 08:37 PM   #1
AutoBahnIstLieb
AutoBahnIstLieb's Avatar
Drives: BMW X1, AMG ML63, Porsche 911
To Run Flat or Not To Run Flat
Hi, new member here. Looking for opinions on runflat tires. Personally, I'm not a fan. My 911 and my AMG both have space saver spares which are the perfect balance between real estate and performance.
My 2013 X1 is the first run-flat spec car I've owned. I immediately peeled them off and replaced with Pilot Sport AS3+.
Are there any decent runflats out there?
      08-18-2020, 10:05 PM   #2
E46M3E84X1
Drives: Xdrive 35i
Send it. #norunflats
darkrom189.50
      08-18-2020, 10:36 PM   #3
BeEmVe
Drives: '14 X1 x28i M-Sport
Run naked ...
      08-19-2020, 01:18 AM   #4
6pan
Drives: bmw x1 (e84)
no run flats they are trash
      08-19-2020, 08:34 AM   #5
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Originally Posted by AutoBahnIstLieb View Post
Pilot Sport AS3+
You put the correct tires on it (assuming you need an all season)
This post sent using 100% recycled electrons.
      08-19-2020, 09:50 AM   #6
0w40X1
Drives: 2014 BMW X1 s28i M Sport
What people don't understand is there's so much difference in strength between OEM 35 psi or 44psi tires and speed rated H, V, W and Y tires.
I used to run only H rated 130 mph Uniroyal Rallye 240 tires, and I'd find occasional nails after they were worn. They seemed like I'd need air once a month, but not a problem.
I replaced my run flats on 14 X1 s28i M sport with Michelin PS4S, and have no worries. I'm not gonna drive flat at reduced speed anyway. I have 6.5 inch bottle jack, jack stand, portable air compressor, and 17mm socket in the car. If flat call tire company and send wheel for a new tire or just tow out.
I got roofing nail in Michelins on other car, and it held air for over a week, so I aired up, and drove to Discount Tire.
      08-19-2020, 01:03 PM   #7
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
No, you made the right switch. I run the AS3+ on my X1.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      08-19-2020, 01:44 PM   #8
Gamb1t
Gamb1t's Avatar
I prefer go-flats.
That said, the X1 is mostly driven by my wife. Therefore for peace of mind we continue to use runflats (Continentals) on her car. I just want to make sure she can at least make it to a safe place (ie tire shop) if not back home.
      08-29-2020, 11:24 PM   #9
NeilinMN
Drives: 996 Porsche C4 Cab - X1 35i
I haven’t made the switch myself yet, but I’m going to. I haven’t quite figured out what my backup plan will be (AAA, plug kit, fixaflat, etc) but One thing is for sure, I’ll be happy to be rid of the runflats.
      08-30-2020, 06:02 AM   #10
0w40X1
Backup plan is a portable tire inflator, bottle jack, and 17mm socket and wrench.
      08-31-2020, 11:57 AM   #11
cwickberg
Drives: X1 35i MSport Ultimate,
Why a Jack? If the tire can be saved, Plug it and inflate...You only need a jack if you are going to remove the wheel...
I have a Tire plug kit and high power inflator... Trained my daughter on it's use, if ever needed... However, AAA is the best thing to have...
      09-01-2020, 01:07 PM   #12
bmw_XPower
Germany
Drives: BMW i3
On my x1 there were flat tires from continental on it. Now I have normal tires on it because the run flat tires are too expensive for me. Up until now I couldn't see any difference
      11-07-2020, 09:37 PM   #13
Jonathan0880
Drives: 2013 X1 Xdrive
Just noticed this thread, I recently posted on this issue. I'm not sure what to do either, by far the RF's are heavy AF and I find it noticeable in performance and sportiness. They did come in handy though when I caught a nail and slow leak over the summer. I'm running Non RF's in winter with a lighter rim, can really feel the diff. It's a great question though, from what I can tell, RF's are just not performance oriented.
      11-08-2020, 11:05 AM   #14
0w40X1
Jack was dirt cheap, even fits in back side holder with quart of oil, and I need in case tire shreds, whole wheel could be taken to tire store instead of towing car.
Also, I need to be able to take wheels off and change brake pads.
I've had vehicles that ran 100k miles and never jacked or changed pads since I'm a watchful braker.
I would only plug in places that can't be patched to try to save tire. If it's in center tread, I'm gonna get to Discount tire. I had a new Michelin PSS that was going flat in a week so aired up and drove over there.
