      02-16-2016, 10:45 AM   #1
Njerts
Drives: x3 m40i
Replacement Fog light
A rock hit one of my fog lights and now it is all fogged up
I want to replace both with new LED fogs, since I have to go through the effort of taking off the front bumper to replace it, I might as well upgrade it.
I understand that it is possible to use X3/X5 fog lights on the X1 since they are mechanically compatible. I can deal with the electrical and coding side to get it working, but I do not want to tackle a big mechanical project.
Does all X1's have the same fog lights or is there a different one on the msport? (Different bumper)
Any help will be appreciated.
      02-16-2016, 11:02 AM   #2
vstolpner
Drives: 2019 F39 X2 m35i
Have you checked the part numbers in realoem.com?
      02-16-2016, 11:08 AM   #3
Njerts
Drives: x3 m40i
They will definitely not have the same part numbers.
      02-16-2016, 12:56 PM   #4
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
The led lights for X3 5 6 are different than the X1. They are bigger and don't match the bracket. I installed them on my X1 but removed the brackets from the bumper and made my own using long bolts molded to the bumper. Also had to cut the opening to make them fit. It's pretty involving project but I'm happy with the result.
      02-16-2016, 01:04 PM   #5
zero-2-sixty
Drives: X1 xDrive35i
I think Bimmian.com has direct replacement fog lights with LED bulbs.
      02-16-2016, 01:25 PM   #6
Njerts
Drives: x3 m40i
Apparently there are 2 types for the X1 depending on msport bumper (see attached)
Is this the one that your X1 came with?
      02-16-2016, 06:01 PM   #7
d1saster
Bulgaria
60
Yes i think i had thise. The difference is in the position of the light adjusting mechanism.
      02-16-2016, 07:08 PM   #8
Njerts
Drives: x3 m40i
Here are the 2 types, one on the left is for msport.
      02-16-2016, 09:26 PM   #9
d1saster
Bulgaria
60
Wow huge difference. It appears the brackets are different as well. The non msport looks like the led fogs of the big brothers but I'm not sure if the diameter is different too.
      02-16-2016, 11:28 PM   #10
Njerts
Drives: x3 m40i
I will measure mine and find something that have the same diameter and angle.
It seems like I will have to make a custom bracket
