      12-31-2015, 12:09 PM   #1
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Suspension Q's
I want to lower my X1 (base model) but I don't want to lower it's ability to handle extra weight. Also it'd be nice if it didn't make the ride any harsher than stock. What spring/strut-shock combo would lower the car about 2", and retain a decent ride? I often carry extra weight in the cargo area, so that's an issue, too. I'm not going racing, I just want a better looking car without losing any utility. BTW, got a JB4 for Christmas!!!
      12-31-2015, 03:51 PM   #2
PrematureApex
Same as everyone else, H&Rs and Bilsteins.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      12-31-2015, 08:34 PM   #3
fw_fw
Freude am Fahren
fw_fw's Avatar
Drives: 18 X3 xDrive30i xLine Phytonic
Best setup out there for the X1.....looks better, rides better, handles better. Be sure to also shorten the bumpstops as part of this upgrade.
Current: 18 X3 xDrive30i
Past: 03 530i Sport | 06 330ci ZHP | 14 X1 xDrive35i M-Sport | 11 328i M-Sport | 98 M Roadster
      01-01-2016, 02:26 PM   #4
Twix
Twix's Avatar
Drives: 2011 e91
H&R won't drop you 2". Maybe an 1 1/4". If you want 2" you'll need a coil over like KW
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      01-01-2016, 08:28 PM   #5
PrematureApex
True. I wish we had a bigger owners group...then we could play around with different E90 springs to see what gets us what.
      01-21-2016, 07:16 AM   #6
GrantE83
GrantE83's Avatar
Drives: BMW X3 E83
So E90 springs go on E84 b6 shocks?
      01-21-2016, 07:57 AM   #7
PrematureApex
It's all E90 X drive suspension wise, with the only significant difference being the diameter of the front strut needed to fit a larger opening in the knuckle. Springs are the same general shape, from what I saw comparing vs. my E series 135.
Just to knit pick, springs don't go "on" the shocks(rear dampeners). They do sit over/go on the front struts (front dampeners) though.
But anyway, unless you have a pair of E90 sedan springs handy and like to experiment with fitment/ride height/etc. I'd stick with either a known quantity X1 specific aftermarket spring, or a height-adjustable coil over.
Problem with the coilovers is that they seem to just use an E90 coilover with a sleeve over the front strut for the larger knuckle opening. This generally means the you're limited how high you can make the rear (like it potentially sits too low for some people's tastes even on its highest setting).
      01-21-2016, 09:31 AM   #8
GrantE83
GrantE83's Avatar
Drives: BMW X3 E83
So E90 Coilovers with a sleeve over the front struts would fit, the only issue is the rear dampeners?
I'm getting my H&R springs / B6 shocks as everyone else seems to have also, but just considering other options for a similar price range.
      01-21-2016, 12:02 PM   #9
kychungkevin
Drives: BMW X1 xdrive28i
I am actually went little differently and got B12 kit which is the same B6 struts but European spec Eibach Pro-Kit Springs instead of H&R. The drop is minimal and Eibach is known to be softer than H&R. Still I am very happy with the setup.
      01-21-2016, 12:30 PM   #10
PrematureApex
There are literally people with off the shelf E90 xdrive coilovers and home made adapters on their X1s.
There is no issue with the rear dampeners, the only potential "issue" would be not having enough travel in the adjustable spring perch in the rear to achieve your desired ride height. (There is no "coilover" in the rear, it's just a stand alone shock, and a spring that sits on a height-adjustable perch.)
You can search in some of the coilover threads, there was a guy with a LeMans blue X1 on KWV3s and his ride height was the highest possible in the rear and still pretty low.
      01-25-2016, 03:47 AM   #11
GrantE83
GrantE83's Avatar
Drives: BMW X3 E83
Thanks,
I have ordered a set of BC racing coilovers now, see how I get on.
Not putting them on untill March / April though..
      02-06-2016, 02:33 AM   #12
Shock96
That was a hell of a thing...
22
Drives: 2013 xDrive 35i M Sport
Looking forward to your review of those BC's. I got an email saying that they were now available for the X drive models.
