11-10-2021, 07:54 AM | #1 |
Rep 53
digital speedometer?
Hi,
Does anyone have a picture of a stock digital speedo in their X1? I'm trying to decide if it's worth adding to my coding list for my 2014 X1 35i Msport. |
11-10-2021, 09:47 AM | #2 |
Rep 485
I put Scangauge II on shelf under gauges. Much easier to read speed, coolant temp, voltage, and mpg. Lots of other parameters. Speed can be corrected.
11-10-2021, 10:10 AM | #3 |
Admiral of the Fleet
265
Rep 3,552
I coded it on and am a big fan. Unlike on other E-series cars with an auto, on the X1, you don't lose any lines either like the odometer or trip odometer. It also remembers it and stays on/active upon the next startup, unlike other BMW's where you have to scroll through the BC stalk each time on startup to pull it up. So, I highly recommend it.
11-13-2021, 08:43 AM | #4 |
Rep 703
This is really interesting. With how I adjust my seat and steering wheel, the top of my steering wheel cuts off my view of the top of the speedometer, so anything over about 40 mph I can't see unless I drop my head down. This mod would totally alleviate that.
11-15-2021, 08:39 AM | #6 |
Rep 53
It's the other way for me. I can't see the bottom, so the digital speedo won't work for me I guess...
11-21-2021, 12:34 PM | #8 | |
Rep 119
11-27-2021, 12:15 PM | #10 |
265
Rep 3,552
I'm pretty sure it's in there. It's one of the most common and basic options on any coding utility, so I'm fairly confident every single one has it. Plus, I nearly got bimmercode back in the day and am pretty sure I remember seeing it there.
The good thing too is you don't need to use it if you don't want to, it just merely unlocks it as another thing to have up as active in your display when you cycle through the BC stalk things (distance to empty, overall mpg, instantaneous mpg, then speedo). |
12-03-2021, 07:03 PM | #11 | |
Not stock
474
Rep 614
12-03-2021, 07:11 PM | #12 |
265
Rep 3,552
I haven't used bimmercode, so I'm not sure. I used ProTool by BimmerGeeks a few years ago on a few cars to do it though. I'm pretty sure that almost any coding tool that works on these cars should have that in there as it's a really basic, standard thing to be able to code on.
02-06-2022, 07:43 AM | #14 |
Rep 52
I have used Bimmercode for the Digital Speedometer,my apology just need to ask,where do I go in the bimmerode menu to be able to do coding for "all doors open/unlock upon engine stop",really a pain when you go out of the car then getting your stuff rear seat but forgot to pish unlock button.Also what other basic coding recommended for e84 using bimmercode.I will try to do a search on these Forums.
[IMG-]http://https://e84.xbimmers.com/forums/album.php?albumid=16469&pictureid=69243[/IMG]
02-17-2022, 11:47 PM | #15 | |
Rep 69
I notice your gauge has a water/oil temp instead of a stupid mileage reading. Do you have a X1? What is the year and model? I have 2014 bmw x1 xdrive28i and interest to know if it can convert straight over with a water or oil gauge? Anyone has knowledge on the wirings? |
02-18-2022, 05:39 AM | #16 | |
Rep 1,543
The digital display between the 2 gauges shows ambient/outdoor temp. Both are stock and I don't see anything different that my stock, uncoded 2014 X1 doesn't have aside from the digital speedo. Mine is a 35i so I'm not sure if the 28i had a different gauge pod (or which gregthegr8 has).
- Jeff
bosstones' flickr |
02-18-2022, 10:08 AM | #17 |
265
Rep 3,552
Mine is a normal '14 X1 35i, stock gauges. I think the 28i's have mpg on the lower right though instead of oil temp.
I think there have been some people on the various forums though from back in the day who have swapped clusters or something for this very reason either on e9X 28's or on 128i's retrofitting 135i clusters. So I think it's doable, may just be a pain. Here's one such thread: https://www.1addicts.com/forums/show....php?t=1462928 |
02-28-2022, 10:21 PM | #19 |
265
Rep 3,552
I don't know if an indy shop would or could do it or if it makes sense based on a shop's hourly rate, which is likely more than it may cost for you to buy an OBD2 device and app to just do yourself among other things. Or you may just want to find some local members who have some coding stuff to quickly do it for you.
You could ask though, should be like a quick 5 minute thing to enable for someone with the right equipment, app, or what have you. |
03-01-2022, 07:43 PM | #20 | |
Rep 92
03-01-2022, 08:47 PM | #21 | |
265
Rep 3,552
03-02-2022, 07:09 PM | #22 | |
Rep 92
