      11-11-2015, 02:38 PM   #1
dimcz
Drives: E84 X1
Unlock 8speed transmission for towing
How to unlock the eight speed transmission for(flatbed)towing?
      11-11-2015, 06:39 PM   #2
vstolpner
Drives: 2013 BMW X1 xdrive28i
I'm not aware that you have to do anything with the transmission for towing. It should be able to sense the added strain and downshifting when necessary.
Just make sure you don't tow too much and that your hitch is properly installed
      11-12-2015, 12:15 AM   #3
Twix
Twix's Avatar
Drives: F87 LBB 6MT
2016 BMW M2  [0.00]
Should be an allen key under the pleather. Then you should be able to push into neutral. Or try to boost it with the tow truck and pop into neutral.
2016 M2 - 6MT
2014 X1 - Sold
2002 Land Rover Discovery II - 3" TF lift - 42" LED bar - 4" LED spots
      11-12-2015, 12:51 AM   #4
dimcz
Drives: E84 X1
No allen key for eight speed, only for six speed transmission.-
      11-12-2015, 02:16 AM   #5
d1saster
Bulgaria
42
Drives: X1 s28i
It's under the car. There's an opening on the liner on the driver's side and you need a tool to unlock it. I'll look for the instructions.
      11-12-2015, 04:20 AM   #6
dimcz
Drives: E84 X1
O.K M/Ths.-
      11-12-2015, 12:04 PM   #7
NormB
Drives: 2014 X1 xDrive 28i
I recall a discussion about this somewhere on the Internet. If I remember correctly, a whole plastic panel under the car has to be removed, and then a bolt has to be tightened. Could be wrong about this, but I think I actually photocopies the instructions and placed them in the car. I'll check further.
      11-12-2015, 12:27 PM   #8
NormB
Found a video:
      11-12-2015, 01:28 PM   #9
dimcz
Drives: E84 X1
B. How to unlock the eight speed transmission for (flatbed) towing?
Answer: Apparently for all 8-speed auto gear boxes (sport or standard) they updated the software to release the transmission using the lever. Red tool is no longer offered in trunk tool kit ...
1: Push start button or attempt to start the car (even if it doesn't turn over, just push it down anyway)
2: Push the lever twice in to N
3: Push the lever to N and hold for 5 seconds
4: Transmission is now disengaged for 15 minutes after which it will re-lock itself.
Remember to repeat these steps BEFORE you roll the car off the flatbed!
      11-12-2015, 02:40 PM   #10
Jump1
Drives: x1 xdrive 28i
Yes, I saw that on an E70 forum, dependent on battery power I assume. Hope that it works on the E84. It would certainly be easier than crawling under the car. With electrical failure, I assume it's either crawl under or use a dolly under the rear end, and pick up the front.
I took a quick look under my X1 and the panel appears smaller than in the video but some tools may still be required. I couldn't see a dedicated access on the drivers side but I didn't crawl right under.
      11-12-2015, 06:38 PM   #11
NormB
That is what I recall from the original step-by-step instructions I once found for the X1--instructions I can't seem to find anymore. The panel is much smaller than the one in the video. No dedicated access, if I remember.
      11-12-2015, 09:38 PM   #12
d1saster
Bulgaria
42
Drives: X1 s28i
Attached are instructions for both electronically and mechanically unlocking transmission.
File Type: pdf Unlock transmission lock electronically.pdf (192.0 KB, 155 views)
      11-13-2015, 12:42 PM   #13
Jump1
Good stuff! Pretty consistent with the video posted by NormB and the electronic method posted by dimcz, but a little more detail.
      11-13-2015, 01:58 PM   #14
Njerts
Drives: '14 X1 28i SportLine
Good information to have handy.
The good news is that apparently no one had to use it😀
      11-13-2015, 02:31 PM   #15
NormB
Except one critical difference that I now remember: you evidently really do need a five-sided driver to screw in that bolt on the X1.
      11-13-2015, 03:48 PM   #16
d1saster
Bulgaria
42
Drives: X1 s28i
In the instructions it is stated to use Hexagon Socket which I think is allen wrench.
      11-14-2015, 10:55 AM   #17
NormB
It is a socket driver version of an allen wrench. They come in standard, numbered sizes. I have a set. BMW uses them a lot. But this does bring up an idea. I am sure a little browsing on the Internet would give one an allen wrench equivalent size to this driver. It would be slow going, but you could move that bolt up with a big allen wrench--assuming you could break the locktite like glue free initially.
      11-15-2015, 10:28 PM   #18
Jump1
Both the video you posted and the .pdf file posted by d1saster indicate that it's a 5mm Allen screw. A hex socket would probably be the best option for leverage, but a 5mm Allen key should work if there is enough room and leverage available. A longer "T" handled Allen key would probably work if the nut isn't too hard to turn. Here's an example on Amazon.
http://www.amazon.ca/BikeMaster-Slid...+wrench+WRENCH
