10-27-2015, 06:26 PM | #1 |
Rep 24
Winter Tires without TPMS
Recently purchased a 2015 X1 and will be getting a set of winter tires installed (non run flats). I didn't get any Tire Pressure Monitoring Sensors with the wheels and was wondering if this causes any issues with the electrical system, other than the symbol being constantly displayed on the instrument panel?
10-27-2015, 06:43 PM | #2 | |
Rep 2,402
You can also code back in the old-style ABS/wheel-speed based pressure monitoring system, and you'll never have to worry about sensors again!
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
10-27-2015, 07:14 PM | #3 |
Rep 280
10-27-2015, 08:25 PM | #4 |
Rep 2,402
10-30-2015, 09:58 PM | #6 |
Rep 10
I learned on this forum a while back that Canadian X1's don't have tire pressure monitors. We have FTM or flat tire monitoring, which, according to the manual, "detects a pressure loss in a tire by comparing the rotational speeds of the individual wheels while moving". No need to mess with code. I am happy to say that I haven't had any first hand experience with FTM and can't vouch for it's effectiveness.
Here's the thread where I found that info. http://e84.xbimmers.com/forums/showthread.php?t=601483 |
10-31-2015, 01:32 AM | #7 |
Rep 673
I can tell you it's quite ineffective. It'll warn you if you get a flat but realistically you should notice it yourself. Plus I think it needs a couple kilometers to confirm that the tire is actually flat.
I picked up our car from the dealership and then decided to check the tire pressure - all wheels were significantly under inflated anywhere from -7psi to -12psi and the FTM system didn't throw any errors. It might have been poor setup on the part of the dealer but I no longer rely on the system whatsoever. The TPMS in my previous US spec Impreza worked great. Though even that only gave me warnings at 5psi under. |
10-31-2015, 06:39 AM | #8 |
Rep 280
A 2015 Canadian X1 should have TPMS. I'm not sure when they added the feature, but it was at least 2015 if not a year or two further back. It's simple to confirm: just look at the valve stems. Metal = TPMS, rubber = FTM.
As for effectiveness, I've been quite satisfied with the results. It picks up quickly depending on how low the tire is. The key is understanding how the system works, which is by comparing the rotation of the two tires on the same axle. If both tires are low, it will be difficult for the system to detect a problem. So yes, you do need to make sure your tires are properly inflated for it to be effective. It's an emergency alert system, but it''s not meant to be a substitute for regularly checking the tire pressures manually. I've had it go off a few times when I had a puncture and very slow leak. Each time it went off while the car was still driveable, at around 7-9 psi loss. So each time I was able to pull over and temporarily re-inflate the damaged tire until I could finally get it repaired. |
10-31-2015, 07:22 AM | #9 | |
Rep 2,402
10-31-2015, 11:58 AM | #10 |
Rep 673
Yeah mine has significant differences between the wheels on same axle and the system never said anything. So I guess that was more incorrect setup on the part of the dealership.
I understand the shortcomings of the system, it was just nice not to have to check the tire pressure with TPMS. Mind you it's nice not to have to purchase sensors for each wheel with FTM :-) For the record my 2013 X1 has FTM |
10-31-2015, 12:24 PM | #11 | |
Rep 280
10-31-2015, 12:51 PM | #12 |
Rep 2,402
Or the system was set when there was a disparity already existing.
10-31-2015, 02:38 PM | #13 | |
Rep 10
10-31-2015, 05:17 PM | #14 | |
Rep 673
Also I have a feeling that run flat vs non run flat tires make aa difference. The ones that didn't respond were run flats and I'm on non run flats now. |
11-01-2015, 07:16 AM | #15 | |
Rep 2,402
11-10-2015, 07:42 AM | #16 |
Rep 24
So turns out my X1 has FTM not TPMS. Not sure if all X1's in Canada are like this but I just got mine brand new, a little less than 2 months ago.
I'm actually glad I don't have to deal with the constant nagging from the system for not having sensors on the winter tires. |
11-12-2015, 10:10 AM | #19 |
Rep 10
While in for service last week, the service manager told me that they still use FTM. He says that he has only seen TPMS on a couple of US X1's, and that BMW monitors @ $500 each (sounds high), would make the cost of winter tire packages prohibitive. I took some time to view the new offerings, and noticed only an i8 ( nice car ) and 7 series with TPMS. It may be an option on some of the other series, not sure. I know that some of the older 3 and 5 series rims for sale on Kijiji come with TPMS, so they have been in Canada for a while.
11-12-2015, 01:30 PM | #20 | |
Rep 567
I picked up a new set of four OEM TPMS with stems for $200 USD on ebay. I put them on our summer set up. The work fine. So certainly search the secondary market. |
11-12-2015, 11:32 PM | #21 |
Rep 336
My Bride's A4 Audi (an '09) has FTM, and it has always worked just fine, and it's mighty nice to put the winters on w/o any nonsense from the system.
Moon |
11-13-2015, 12:11 AM | #22 |
Rep 673
If I recall correctly Audi has proven their system to be good enough that in the US they don't need dedicated TPMS sensors in each wheel. No other company is allowed to do this in the US
