01-22-2014, 12:46 PM | #1 |
Rep 19
Traction control flashing while turning
This is a 2013 X1 3.5. I've noticed that when I try to accelerate hard from rolling and turning, I occasionally get the traction control light to flash, and power is reduced significantly. The thing is that this is on dry pavement, and I'm feeling no tire slip whatsoever.
Am I being a hypochondriac, or is this something I should look into? |
01-22-2014, 12:50 PM | #2 |
Rep 790
Well...sounds like the car thinks there is a loss of traction. If it doesn't feel quite right to you, then perhaps there is a faulty sensor or something. Worth a trip to the dealer if it is bugging you! I have yet to see the traction light come on during any of my "spirited" driving outings.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1 Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i |
01-22-2014, 02:17 PM | #3 |
Rep 9,160
Which tires have you got? If A/S, this is normal. Hold the DSC button for ten seconds to fully disable and see if you are getting tire slip in similar situations.
Even if you have summer tires and it's 40 f or colder, this is normal. |
01-22-2014, 04:03 PM | #4 |
Rep 1,563
01-22-2014, 09:45 PM | #5 |
Rep 1,922
Drives: 2011 e91
Just about any cat with traction control will do this. If the steering angle and throttle angle are high, the computer will anticipate wheel spin our more importantly an oversteer condition and compensate. You can turn the traction nanny slightly off (quick push) and then the DSC off by pushing and holding the traction control button for about 5 seconds
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
01-23-2014, 03:04 PM | #6 |
Rep 80
After always turning off TC (one brief press) the X1 is a new animal. Mine was kicking in on straight, dry pavement. Huge difference in acceleration.
I thought DSC only kicked in if it was over steering noticeably? I haven't been nailing it through corners much though... Or is DSC "trigger happy" to activate itself like TC is? |
01-23-2014, 03:06 PM | #7 | |
Rep 1,563
DTC on the other hand just ruins the car. Even with my summer tires (probably since I am tuned). |
01-23-2014, 08:29 PM | #8 |
Rep 1,922
Drives: 2011 e91
I can get my 28i to get a bit sideways on an on/off ramp with dsc on. But as soon as I lift the throttle the dsc kicks in really makes for fun (read; horrifying) time.
2011 E91
01-27-2014, 01:09 PM | #9 |
Rep 19
Thanks for all the replies. Pondering more and talking to some local people, definitely sounds like intended behavior. I just never had this on my 335, so I was surprised by "anticipated" wheel spin kicking it on. Joys of open diffs, I guess.
I would do more testing, but we keep getting snow, so I doubt that will be a legitimate test... |
