      08-31-2017, 06:48 PM   #1
Tary
Drives: BMW X1 E84
E84 radio wiring help
Hello to all, I'm new to BMW and I bought an used 2012 E84. I want to replace the radio.
the model I have is 6512 9283717-3, it is not working properly and I want to replace it.
The problem is that, when removing the radio I found to cables other than the main cable bus.
One has pink termination connector the other has a black termination connector, please see attached pictures. Can someone tell me what does these cables do, I assume they are antenna cables...but for what.
Thank you very much your forum helped me on finding information on how change oil, replace lights and open the dashboard....
      08-31-2017, 07:34 PM   #2
kiloTHREE
Drives: '13 xDrive28i
Ones satellite radio, the other fm/am.
      08-31-2017, 08:15 PM   #3
Tary
Drives: BMW X1 E84
Thank you for the reply do you know the connector types used, so I can build/buy a pig tail to connect them to my new OEM radio ....
regards
      08-31-2017, 08:22 PM   #4
kiloTHREE
SMB connectors but not sure what size.
Tary1.00
      09-02-2017, 03:51 PM   #5
Tary
Drives: BMW X1 E84
The two images show the bus cabling attached to radio mentioned above.
Does anybody know what the 2 green cables are and where is the Battery + and - poles are in the bus....
Even better whee can I get bus cabling wiring plans for E84 ????
Thanks
      09-02-2017, 03:54 PM   #6
Tary
Drives: BMW X1 E84
KiloThree thanks a lot got the antenna pigtails done today.
Regards
