      07-11-2017, 03:30 PM   #1
cheychey
Drives: 2012 BMW X1
No Alarm Possible to retrofit?
I have a 2012 bmw x1 without the alarm and security system. Is it possible to retrofit? Are the x1 prewired? Any third party alarm options?
      07-22-2017, 01:53 PM   #2
cheychey
Drives: 2012 BMW X1
If i get these parts would I be able to install them and have it working? Or would I need coding?
      07-24-2017, 12:22 PM   #3
kapetajr
Drives: 2015 E84 X128I
Yes you can install those & then you need activate the module by having $302 added to your VO.
2015 E84 x128i/Alpineweiss/TunerWerks Module/E38 MPARS/
1991 Toyota Soarer - turbo6
      07-24-2017, 03:37 PM   #4
cheychey
Drives: 2012 BMW X1
Thanks so much for the response. I guess Carly can code for the system? or do I have to use NCSexpert?
Originally Posted by kapetajr View Post
Yes you can install those & then you need activate the module by having S302 added to your VO.
      07-24-2017, 04:00 PM   #5
kapetajr
NCSexpert/ISTA P would be the best option. I dont think Carly can add VO'S
      07-24-2017, 04:05 PM   #6
cheychey
Drives: 2012 BMW X1
Thanks will keep that in mind.
