      07-02-2014, 09:17 PM   #1
wantm135i
wantm135i's Avatar
Drives: x1 35i m sport
jb4 n55 codes need help on bmw x1
hi all i got everthing installed er charge pipe, ar down pipe, er inter cooler, jb4 tune and flex fuel wires, burger cold air intake. when we went to start x1 we got codes. trying to fix today. if you installed jb4 n55 when you started up your x1 or 335 or 135 after install of jb4 and flex fuel did you get any codes?
also did you have to update any soft wear for the jb4 n55 or for the flex fuel?
also did you do any data logging yet?
lastly i remember some one saying dont hook up the mass air sensor? why? i emailed jon at burger and he said hook it up maybe its something different.
please any advice would help.
_________
      07-02-2014, 10:29 PM   #2
EdgeCrusher
Drives: M3
If I were you... Doing all the mods at once was probably a big no no.. I would have done one at a time and check for leaks.... I dont know about the flex fuel wires, but you have been running this tune for awhile now with no issues right? I suspect the downpipe and or charge pipe is throwing the code.... it's hard to tell with out knowing what codes are being thrown. Most guys at this stage have the bavarian scanner tool. That should be your next investment!
      07-03-2014, 12:40 AM   #3
Blaumph
Blaumph's Avatar
Drives: '13 X1 35i Msport
Did you cut the diode on the board and upload the ISO firmware for the JB4? I have the ER CP, BMS intake, Flex fuel wires, and oil catch can installed with JB4 (ISO 5.3) and am not throwing any codes.
The last log I did was just with the JB4 installed on 91 gas. No problems there though. I also read on n54tech that once you go ISO, the MAF sensor is no longer used. But I also read that it wouldn't hurt, so I left it plugged in.
Did you look up the codes?
      07-03-2014, 07:57 AM   #4
wantm135i
wantm135i's Avatar
thanks the codes are - let me get them ....
      07-06-2014, 02:44 PM   #5
wantm135i
wantm135i's Avatar
running iso tuneing is for ones who want or are running meth right.
and if iso is what i should be running with all my mods i wonder why jon or terry at burger tuning didnt advise me of this. the x1 has been down for over a week now just trying to email back and forth with burger tuning to get the car running with out codes and check engine light.
      07-08-2014, 08:16 AM   #6
wantm135i
wantm135i's Avatar
now my tech doesnt wont to work on trying to fix codes and check engine light hes frustrated. What about me fronting all this money, and cant even drive my car now. does anybody know a shop in washington dc that has an all wheel drive dyno and is experts in tuning with jb4. help need thanks
      07-08-2014, 12:49 PM   #7
EdgeCrusher
Drives: M3
I'd just remove everything and start all over... your going to be spending a lot to trouble shoot all the mods you did.... there could be a leak in the IC piping, downpipe etc.... I'd start with the JB4 then add the down pipe, then add the I/C
      07-13-2014, 02:33 PM   #8
wantm135i
wantm135i's Avatar
ok with all mods added with stock computer no codes, turbo spools much faster and exhaust burble is amazing. while trying to hook up jb4 keep getting codes. so we just sent it back. burger tuning is checking and will send back.......
      07-14-2014, 05:38 PM   #9
wantm135i
wantm135i's Avatar
cant believe there was a wire that was not connected. So simple. ugh
      07-16-2014, 03:57 AM   #10
maui86
Drives: 07 335i
If you're able to post a video of the exhaust under acceleration and decel that would be amazing and greatly appreciated.
And an acceleration speedo video. On a private track of course. Haha.
Thank you!
Teri
http://videos.streetfire.net/video/s...rays_37268.htm
gotta do what i gotta do to get them donuts
04 spec-v: rip dec07
      07-16-2014, 11:59 AM   #11
EdgeCrusher
Drives: M3
it's always the simplest things!
      07-18-2014, 11:01 PM   #12
wantm135i
wantm135i's Avatar
what the this x1 so i set it to auto tune map 5 and did 3 runs from 2500 to max after that dag on rocket. i just need to reflash my trans with the alpina trans flash will be good to go
      07-19-2014, 07:03 AM   #13
themishmosh
Drives: BMW X1 xDrive35i
Did you need to revert to stock prg for some reason?
      07-20-2014, 10:36 PM   #14
wantm135i
wantm135i's Avatar
no the alpina trans flash mess up a little when the battery was unhooked lost single for paddles
