      11-22-2017, 07:24 AM   #1
johninjax
Drives: 2014 X128i LeMans Blue M Sport
brake job
Need front brakes and rotors and have always used BMW parts, looking to use Akebono. For those that have used them how do they compare to BMW parts, initial grip, distance etc...
      11-22-2017, 08:28 AM   #2
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Can't say anything about those, but I put Hawk pads and StopTech rotors on mine (all around) and love them.
Much better feel, more of a progressive feel versus the original which had more of an on/off feel to them.
      11-24-2017, 05:48 PM   #3
Mr_Jack
Drives: X1 35i M Sport
John,
What budget do you have? That can help in selection. We use the following brands at my shop - Stoptech 309 formula if you are looking for more bite paired with EBC or Stoptech rotors, textar/jurid for OEM formulas and rotors(both those brands along with ATE make OEM BMW pads/rotors)
I've used Akebono before in Japanese cars, but never tried on a BMW.
'15 E84 X1 35i M Sport
MPI DME Flash - K&N drop in - MPI Chargepipe - Oil T-stat valve - ETS 5" I/C - N54tuning 3.5" downpipe - catless mid section - Dinan 135i rear exhaust - Apex ARC8 18x9/10(255/295 tires) - H&R Sports - Bilstein B6's - F3x M Performance brakes
'02 E39 530i 624whp/558ft-lbs @23psi
      11-25-2017, 10:06 AM   #4
johninjax
Thanks, thinking OEM.
      11-25-2017, 07:49 PM   #5
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
Did my rear brakes last year using Akebono pads and, IIRC, Centric rotors with painted hubs. Saved the wear indicator and re-used it. I notice zero diff in pedal feel, initial bite, or any other attribute. I also bled off about a 1/2 pint of fluid. I’ll be doing the fronts in a few months and will again use Akebono.
      11-27-2017, 08:29 AM   #6
kiloTHREE
Drives: '13 xDrive28i
I only use Akebono euro ceramics in the past 10ish years across multiple cars.
You will loose some initial bite compared to oem but the trades offs are worth it.
Low dust and great feel.
      03-15-2018, 12:56 PM   #7
SharpAndCunning
Drives: 2014 X1 35i
Are akebono and TRW comparable?
